Aftermarket electric fan wiring
Tried a search, can't find the info I need.
Can someone direct me to a thread or something that explains how to wire an aftermarket electric fan to be controlled by the PCM?
My 5.3 has a regular crankdriven fan but I am deleting it because of space issues. My computer has been retuned to control an electric fan now but I don't know how to wire it.
Thanks
Thanks
Relay. The pcm wire is used for the trigger voltage to turn relay on. U still need to wire up power to relay and relat to fan using heavier gauge wire. Google relay wiring. I believe a goo info site is called " the 12 volt" or something like that
Not sure what number or which connector the wires are that show going to PCM
How I was going to wire up fans was one of the things on the to do list. Haven't done much searching on it yet though.
first of all, what fans are you using, duel or single ?.. can the fan(s) support Low/High speeds ?
If they support 2 speeds, get the relay wiring diagram for a 4th Gen F-body (its been posted many time before) and just wire it up that way. the PCM will supply a ground signal as stated above. The FAQ is here with the wiring pin out to terminal of the relay.
https://ls1tech.com/forums/conversio...swap-faqs.html
Also this is the OEM 3 relay setup
https://ls1tech.com/forums/attachmen...-here-fans.gif
If only one speed, then just wire up a relay one per fan with the ground connected to the PCM (Blue 42 for low and Red 33 for high or the 2nd fan). This is just a basic Relay powering a electrical device (Fan, pump, etc). (Edit: see boxchev setup)
BC
BC
I just bought a single 16" fan, and I don't know if it supports two speeds or just one. I assume I will find out when it arrives.
I am a total novice when it comes to wiring anything. Where do I get the correct relays?
Just about any Relay will work that has the correct rating on amperage, that being a 30 or 40 amp relay.
But I would suggest you should get one that has a sealed base / connector and has mount on it like a OEM one. Painless has a complete setup (as many other manufactors and companys). You would have to wire the Black ground wire to the PCM to give the signal to activate the relay and power up the fan.
you can order or find it just about anywhere... Summit, Jegs, local Speed shop or stores.
BC
BC
Point taken! I shouldve specified it grounds the relay. But it can still be considered to " trigger the relay". . On another note, you can also ditch the pcm all together and just get an aftermarket radiator probe with an adjustable dial to " trigger" a fan relay and power up a fan.
