4L60E Trans wiring
Yes sir, that part I understand. The other end of the harness has a plug on it too.
This is the plug that plugs into the trans. There are multiple wires same color
This is the other end of the harness and I need to figure out which yellow and black wire corresponds to the yellow and black wire at the other end. There are also two white wires on this one and only one on the trans end
2001 Corvette. This one has a plug on the trans and a long harness that plugs into another plug that goes to the PCM. I will get in there and run a continuity test to find out which yellow and black wire is which....
Scan gauge 2
I have a 2003 ECU with 6.0 4l80e installed out of a Heavy duty truck in my 71 c-10 . I have a stand alone harness.
Can someone tell me if the transmission fluid temp can be turn off/on feature that my tuner can do.
I bought a scan gauge 2 reader and was hoping to read transmission fluid temperature but it doesn't pickup a signal from the ECU. Can this be turned on/off by the tunner?
Thanks for any info.
