240sx 76mm 5.3L TH350 E85 "Pics & Vids"
Whats up fellas, this my build thats been going on for a while now I figure I make a thread of it already.
Originally I was Ka-t making 418whp on 15 psi 61mm turbo which was not bad at all keep in mind it was stock longblock, I had fully built components ready to go in cams, pistons, rods, etc.
However my deal old friend said quit the bulls**t and run bigboy status, put a LS1 in your car. My response "im faster then a STOCK LS1" his response fine ricer put a turbo on it.
2 days later he donated my a LS1 longblock, from there I started:
Long story short I moved from FL to MD where I knew NO ONE. So I was solo at this point which made process real slow BUT I got it done 4-5 months later.
setup was:
Stock LS1 Gen3 33k miles
317 heads
GM MLS
ARP Head studs
Comp 918 valve springs
stock cam
stock intake
ATI dampner Crank Pulley
No PS or A/C
custon 3" intercooler and piping
truck manfolds
Lucas 120lb Injectors
E85 w/ Aeromotive 340 stealth FP
Megan FPR
Aftermarket Fuel rails
GM 3 Bar MAP
HP Tuners
Built JW TH350 (reverse mvb)
JW loose 4500 stall
Full Q45 rear end (3.54 Final Gear)
Hurst Shifter
Im sure theres some other stuff I cant remember of the top of my head.
got it running on 4 psi.
on 4 psi after 5800 rpm I would get valve float.
Fast forward life 3 months later lifter took a ****, thought it was a rod knock.
teardown,
little one
then I decided to go Iron block after being on for ages and ls1tech.
so she finally came,
Got all running then a alternator bracket bolt appeared in cyl. 1 intake valve and smash broke the piston and skirt along with bending the valve. sighhhh
At this point I was losing hope. but it was my mistake so I continued and gave it one last shot. this time I changed it up.
5.3l block
317 heads (cleaned, valves re-seated)
Lunati .660 lift gold spring kit
comp cam chromoly pushrods 7.400"
LS7 lifters
comp cam 235/239 .621/.624 114+4 LSA
button it all up together
oo also I changed the wastegate spring to 16 psi. lol
DONE!
Still have to fine out the tune has some lean areas under part throttle mainly going uphill. I did one pull in 2nd gear and WTF it was retarded and unexpected, the cam is amazing.
datalog showed 16 psi at 24 degrees of timing at 12.1 AFR and no sign of any knock. I added fuel to 11.0 AFR and dumbed the timing to 19* just to be safe because I found a boost leak and fixed but havent driven the car since that.
More vids and pics to come. Enjoy! Let me know what you guys think?
setup was:
317 heads
GM MLS
ARP Head studs
stock cam
stock intake
No PS or A/C
truck manfolds
Megan FPR
GM 3 Bar MAP
HP Tuners
JW loose 4500 stall
Hurst Shifter
teardown,
little one
5.3l block
LS7 lifters
DONE!
Driving is awesome I love how fast it shifts and grabs, it was on a loose stall now its on a tight stall. Highway was bad i couldnt keep up with traffic unless I was at 3500 rpm.
heres the formula I used
for cruising, Speed x 336 / Tire dia. x Final gear ratio = RPM
for tight stall wot, Speed x 355 / Tire dia. x Final gear ratio = RPM
for loose stal wot, Speed x 360 / Tire dia. x Final gear ratio = RPM
I have a pathfinder diff. which im going to swap in and it will drop my final gear from 3.54 to 3.13.
thats kool man. i cant wait to finish mine im using a borg warner 4 speed, i may/ probably will have the same problem.im thinking about using 350z rear and axles to lower my rear gear
You are f**kin crazy....AND I LOVE IT! Lmao I wanna go for a ride that **** looks like you wouldn't be able to tap the dash from launch to fourth. Sorry tap the dash is a game my uncle and I would play after building his el camino and my camaro. Passenger has to try and tap the dash where it meets the window during launch and so on while being pushed back into their seats from the torque. It's loads of fun give it a try. Lol
sorry for the late response lol. but its a regular t 10, date code says from a 62 corvette. i wish i had the coin for a super t 10. and im not sure what the actual hp rating is but it handles my my cammed 5.3 with no issues. only problem im having is shifting, at first it was my shift linkage, but now somthing else is going on. it will not shift at high rpms with the tires spinning, so still gota figure that out.
