Holley Sanden A/C bracket
Old 12-14-2012, 09:31 PM
Rocketrod's Avatar
Originally Posted by 55chevy
I recently replaced my Kwik bracket with the Holley A/C bracket. I have a Sanden 508 compressor and I'm running the stock 2001 LS1 Corvette alternator/ps bracket on the other side. The Holley documentation was great and the fitment perfect.
Here is one picture with the Kwik bracket and 2 pictures with the new Holley bracket.
Looks great! What type of paint and prep was required to paint the engine covers?
Old 12-15-2012, 06:28 AM
55chevy's Avatar
Sorry, I don't know all the details. The guy that painted my car, painted them. I don't know how he preped the covers but I'm pretty sure he just used the same base and clear coat as he used on the body. They have held up very good, no cracks or flaws in the paint. I have about 10,000 miles on the conversion. Thanks for the praise.
Old 12-15-2012, 10:03 AM
Gray86hatch's Avatar
I am installing them now on dads car. I blasted them and painted them with epoxy satin black. They look really nice. I will get some pics today.
I also sanded out the casting seams before I painted them it really helped the finished look
Tim
Old 12-21-2012, 07:19 PM
Rocketrod's Avatar
I put about 30 miles on the car since I installed my bracket. After about 10 miles and a couple hard launches the belt chirps all the time except at idle.
Old 12-21-2012, 08:00 PM
alocker's Avatar
AC on or off? Could be a bearing of one of the pulleys also.
Old 12-21-2012, 09:37 PM
Rocketrod's Avatar
AC is off and everything is brand new compressor, pulleys, idlers, belts, tensioners, etc. I haven't even yet popped the hood to look at, but I will find some time to do so this weekend.
Old 12-21-2012, 10:01 PM
Just finished dads install today worked out great.
If you are slipping a 6 rib belt you have something tight or the belt is too long.
With no ac and stock truck parts a 97 vette belt was perfect
Tim
Old 01-02-2013, 01:47 PM
RicOtt's Avatar
I had the same "chirping" problem with my LS style 6.0 in a 66 GTO. After replacing almost every part (Waterpump, altinator, Harmonic Balancer, Tensioner and Idler pulley), the noise remained. Turned out the pressed on pulley on the Power steering pump (that I pressed on) was approximately 1/8 out of line. I highly recommend that you look at the alignment of the power steering pulley - that is probably your problem.
Old 01-02-2013, 09:07 PM
Rocketrod's Avatar
I will check it out, but I put about 500 miles on the car before I installed the A/C . After putting on the A/C the chirping began.
Old 02-13-2013, 06:13 PM
suttoncurt's Avatar
Subscribed !! I'm in need of this set up for my ls swap . Great info guys . Thanks for posting
Old 02-13-2013, 07:36 PM
donnie_19's Avatar
Originally Posted by dirtymoe77
Hey guys, I just got done installing this setup. Extremely well put together. Please excuse the mess of an engine compartment. I really hadn't planned on sharing these so I didn't really pickup. Have stuff all over the place. I highly recommend this setup. Everything went together very nicely. I polished mine and got chrome goodies to go with it. Any questions let me know.
Getting ready to install this set up on my 78 vette. What length is that throttle cable and is it a lokar? What PS pump did you use? Vette 99?
Old 02-15-2013, 11:09 AM
  #32
ijimmy's Avatar
here ya go not in car yet and i still need to put a power steering pully and different water pump but that will be in short order , the ac side is done
Old 03-01-2013, 11:12 AM
  #33
ijimmy's Avatar
Old 05-31-2013, 02:50 PM
  #34
Blue67LS2's Avatar
Anyone have a part # for a belt using Corvette accessories and an SD5 compressor? I tried the one referenced for a SD 7 and I think it's too short.
BTW - I'm very impressed with the Holley bracket and highly recommend it!
Old 03-03-2017, 10:49 PM
  #35
the450r's Avatar
Anyone know the right belt for fbody accessories and this bracket and the sd7???
I have a 5060990 or 6pk2515 and it's too long....
Old 03-05-2017, 06:03 PM
  #36
chuckd71's Avatar
Buy a handful of the next shorter belts, try them, return the ones that don't work.
Old 03-06-2017, 10:02 AM
  #37
the450r's Avatar
That's what I'm doing. 60980 is too small 60988 884 on the way. Figured someone has done same setup by now. I'll post what fits
Old 03-07-2017, 09:27 AM
  #38
the450r's Avatar
This is with the 988. The instructions don't show the third mark.. 988 looks right to me. 984 is alot closer to the first mark. With some stretch it would be right in the middle the lowest mark is right at full compression of tensioner. And where the 980 belt was.
Old 03-07-2017, 10:18 PM
  #39
the450r's Avatar
These are with the 984 much tighter on the tensioner wear grooves.
The I noticed how crooked the belt is. I tried bigger washers at the front to move the compressor out still looks off. I'm not sure if my Holley brackets are wrong or the compressor is the issue. I figured all the sanden compressors would be the same. This one is made by tuff stuff I got locally. I'm going to try to contact Holley tomorrow.
Old 03-08-2017, 09:31 AM
  #40
Toddoky's Avatar
Measure the distance from the rear face of the front mounting ear to the second belt groove from the front of the pulley; the Holley supplied compressors measure 2" to that point as shown in the attached photo. If yours measures the same, you'll have to contact Holley Tech Service to resolve the issue as I don't have the means or bandwidth to check anything beyond the compressor pulley dimension.
Quick Reply: Holley Sanden A/C bracket
