Is my driveshaft too short?
Yes
You will snap the splined input...ask me how I know...
If your lucky it wont destroy your tail housing and tear thru the floor pan...
shim your drivelines angles optimally, and remeasure... you should get perhaps max 1 inch of the splined slip joint sticking out past the rear seal...
T
T
Only way to tell is to disconnect it from the rear yoke and push it all the way in...should only pull back out about 3/4" or so from bottomed out to attach to the rear.
To do it the correct way you need to measure the distance between the rearend and trans. Here are the instructions http://www.dennysdriveshaft.com/how_to_measure.html
T
T
OP, How long is the yolk? Just because you see a lot of shaft sticking out, doesn't mean you have too little engagement.
ranny. Will have to disengage the drive shaft but it will have to wait because I'm going out of town. I think my pinion needs to come up more. I added 2.5* shims but it still vibrates - especially on decelleration. Also my rear is leaking from the pinion. What a headache.....
When I measure from my starter it seems my engine/tyranny is 5* down and my pinion is about 2.5* up. I hope these vibration blues are cured soon.
Not sure. From what I understand there should not be anymore that .75" of play between the yoke and
Obviously you have plenty of yolk cushion from bottoming out, now the question is just how much engagement you have.
I measure angle from the U-joints with a magnetic angle finder.
