4l60e controller for a carb'd ls 69 truck
Old 01-28-2013, 12:20 AM
billyflantos's Avatar
Default 4l60e controller for a carb'd ls 69 truck
whats the cheapest controller you can get for a 4l60e...i have a carb'd ls1 69 truck running off a msd 6010 box...thanks.
Old 01-28-2013, 01:08 AM
68 TT's Avatar
The stand alone Transmission Control Module GM put behind the 91 to 93 diesel trucks. Not super easy to find but cheap at a pull it yourself type wrecking yard.
Or you can take the 94-95 vintage 16197427 PCM from the C/K trucks & SUV's and the S10 & Astro and modify the bin to make it a stand alone transmission controller. Moates file server has data files on what is needed to do this.
Old 01-28-2013, 01:36 AM
is their a afterarket company thats makes them?
Old 01-28-2013, 06:04 AM
LS1Tech Sponsor
psiconversion's Avatar
We sell the TCI Transmission controller kit. Check it out.
http://secure.ultracart.com/catalog/.../ACC-1034.html
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 01-29-2013, 08:27 AM
tennerv8's Avatar
Optishift works awesomely. Member denmah uses these in his fairmont.
Old 01-31-2013, 12:03 AM
Jon
PSI
so all i need is this and a tps and plug it up punch a couple buttons and im on my way?
Old 01-31-2013, 06:29 AM
LS1Tech Sponsor
YES.
Jon
PSI
__________________
Ebay Store
Old 01-31-2013, 03:07 PM
downset71's Avatar
Are there any issues at all with TCI setup? Just based on fact that it looks like a FAST rich-lean setup turns me off. I had to send mine dual O2 setup back to FAST 4 times within 3 yrs. finally threw it out after using for maybe 10 runs. Biggest waste of $ and time
Old 01-31-2013, 05:01 PM
Is there any provisions to hook up a aftermarket electric speedometer?
Old 01-31-2013, 05:06 PM
buddhaz06's Avatar
Yes. I'm selling my 4l60e tci ez-tcu fwiw
Old 01-31-2013, 06:31 PM
tonypaul's Avatar
These are less expensive, but not sure if it has all features you want/need:
http://www.magnashift.com/magnashift_controllers.html
I got the TCM806 for my 4t65ehd but I havnt installed it yet, but these controllers came recommended to me by a very good transmission builder that has been using them for a long time.
Old 02-02-2013, 12:45 AM
QUOTE=psiconversion;17097525]We sell the TCI Transmission controller kit. Check it out.
Jon
PSI[/QUOTE]
will i need a tps or will it run off my tach output on my msd 6010 box with the tci trans controller?
Old 02-02-2013, 04:19 AM
LS1Tech Sponsor
Yes, it needs a TPS signal to operate correctly.
Jon
PSI
__________________
Ebay Store
Quick Reply: 4l60e controller for a carb'd ls 69 truck
