What are these wires/vac for? Fox.. picture
Garbage emissions stuff, only one vacuum line needs to be kept.it goes in the fire wall by the heater hoses.it for the belnd door vacuum operation.youll use the gm pressure switch and then you should hook up your ac request wire inside the car iirc to trigger the compressor.the ac system is controlled by by the gm pcm.i would keep the ford lines tho for when you have new ones made
