wiring up aftermarket gauges
Anyone have a good resource for wiring aftermarket gauges into the harness?
I am a TOTAL loser when it comes to anything electrical, I just want to have some kind of guide for the guy who is doing my wiring for me.
If it matters, I am using Speedhut gauges, (speedo, tach, temp, oil, volts, fuel) stock 5.3 truck harness. I know they don't all tie into the harness though.
Thanks all
Thanks all
I'd assume each gauge will have its own sending unit, so they won't really tie into your existing harness.
Tach signal will come from a PCM output (I forget what wire, but its listed on lt1swap.com). Speedo input can come from the PCM as well (assuming its compatable with the LS PCM signal. The PPM can be changed via HPTuners).
LS1Tech Sponsor
Do you have a standalone harness or reworked harness? What is the engine application?
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
You should be fine with speedhuts, the manufacture them so a brah dead monkey could wire them up, All blacks go to ground, all whites go to lights on 12v, all reds go to switch 12v. And the yellow tach wire will go to a PCM signal for the output,
The way speedhuts work you can tune it to any signal, You could hook it directly I a coil if you wanted
LS1Tech Sponsor
Speedo pinout is PCM Red plug, position 50, Tach is PCM Red plug, position 10, mil lamp is PCM Red plug, position 46. Water temp and oil pressure are going to use the Speedhut senders. Not sure if that was the information you were looking for.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Yeah Jon I think that's exactly what I need. Thanks a lot!
help with wiring please.
I'm not sure what to do. I connected my 2003 blue and green sides computer pin number10 directly to a pull-up resistor and then to the gray wire going to my tachometer Sender side I have set my tech ometer to 4 cylinder as I have been told it will read the pulses. still not functioning. am I supposed to run another wire from the ignition back to a coil I'm not sure if I've done something wrong somebody please help it might be easier to call me on the phone 5614 12 9543 my name is Wayne thanks for any help
Another option is our LS Gauge controller if you don't want to run sensor for all of the gauges. Check it out here:
https://ls1tech.com/forums/new-produ...ontroller.html
Tach
I have the white wire coming out of 10 10 going to the resistor then to the gray wire that goes to the signal side there is power through my instrument panel going to the ignition side and there is ground from the underneath of the tack grounding am I supposed to put another power source somewhere
Why do I see diesels schematics being wired to the alternator also I read something about an aftermarket adapter called a 9117 I'm wondering if I should install that
