5.3 swap
LS1Tech Sponsor
This is getting to be a common swap. Motor Mounts, Harness, Fuel System Upgrade, PCM tune. One advantage to the trucks is the hood clearance doesn't force you to switch to an LS1 style intake manifold, you can keep the truck one so cost stays down. Shoot me a PM/email or give us a call we have whatever you need for the swap.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Its a really easy swap! i am in the process of doing this same swap right now. i am building my own harness from a take out. It is very easy but also very time consuming to make sure its 100% right. I definately recommend Jon with Psi, he has been helping me out a lot with very useful info. Check out my thread i just posted.
LS1Tech Sponsor
Typically the harness only needs constant power, switched power and ground. However, we do provide additional wires, some are optional others are recommended. The recommended wires include check engine light and tcc (if electronic automatic).
Jon
PSI
__________________
Ebay Store
Ebay Store
LS1Tech Sponsor
The pcm does not provide an oil pressure signal to a gauge, if the signal is provided from the pcm it comes over the data bus. In the early gen 3 vehicles the oil pressure signal came directly from the sender to the gauge. The factory sender signal is not compatable with aftermarket gauges. Most generally the gauge manufacturer will provide a sender for this application.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
Well then your oil pressure signal will come directly from your sender to your gauge set pigtail.
__________________
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
Sarge,
We have some of the f-body gage pinouts on our website www.psiconversion.com/diagrams.html We are constantly adding a number of schematics to this page to help people with their swaps. Just an FYI, we sell a pigtail for the f-body gage cluster if you dont have one and even if you do, our instructions for the cluster will detail how you can wire it up. Let me know if you need anymore information.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
LS1Tech Sponsor
Signal comes from the Serial Data wire. Typically people splice into it on the OBDII port.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
LS1Tech Sponsor
When you examine the connector pinout you will notice that there are some gauges that do not have a pigtail, these gauges come over the data bus. The gauge leads that still have a pigtail, you will wire the sender or signal wire to that lead.
__________________
1-888-467-4491
1-888-467-4491
