Project ls swap c10 *update post 48*
Old 02-25-2013, 10:14 AM
Blackpony's Avatar
Default Project ls swap c10 *update post 48*
Well I have finally gotten around to starting the swap in my truck. I have been gathering parts for almost a year now. Been scanning ls1tech, buying from friends or friends of friends. Still have a ways to go, but hoping within the next 2-3 weeks, it will be running. Still waiting to get the heads back from the machine shop and need to order a hand full of misc parts and wiring.
The shortblock:
How it sets right now:
Building of the wiring harness, about 2/3 done with it:
Wiring harness is 80% done
Old 02-25-2013, 02:47 PM
JacobIroc's Avatar
Looks like a good start. Are you going DBC or DBW?
Old 02-25-2013, 02:53 PM
Blackpanther99's Avatar
Man that wiring looks like a pain in the ***. lmao
Good progress bud.
Old 02-25-2013, 03:41 PM
Capown's Avatar
That looks sooooo much easier with the intake on a bench! I need to do that with my harness and stop being Fuqin lazy! Looks good man I'm diggin the crinkle paint im gonna have to copy you on that.
Old 02-25-2013, 05:16 PM
Blackpony's Avatar
Im doing dbw. Will be much easier and cleaner along with making the cruise work.
Good progress bud.
Meh honestly its not that bad. With all the info available, its more time consuming than anything. i changed how the harness routes so its taking a little longer. If I were to do it again, i would route the tb and maf harness through the valley and flip the injectors around and make it a little cleaner.
Yeah, i was hoping to have the motor assembled and on a stand to do this part, but my heads are at a buddys shop getting ported and i needed to set the motor in before i returned the cherry picker, so that kinda screwed me, but doing it this way isnt that bad.
Oh and all the covers are powder coated. I get a hookup on coating through the shop i work at so it wasnt that much more to just coat rather then paint.
Old 02-25-2013, 05:30 PM
ls1nova71's Avatar
That seat doesn't look OSHA approved! Looks good so far, sucks you had to put the short block in before putting the heads on, but you gotta do what you gotta do sometimes. Good luck with the build.
Old 02-25-2013, 08:18 PM
Blackpony's Avatar
Thats my trash can. i dono what your talking about...
Old 02-26-2013, 11:49 AM
darren roar's Avatar
Im waiting on a couple parts to start my C10 swap. Good luck with yours.
Old 02-26-2013, 12:17 PM
84hernandezc10's Avatar
Looking good. I'm in the middle of my swap also. I started the wiring hopeing not to be in over my head. We will c how it turns out. Good luck with your swap.
Old 02-26-2013, 01:30 PM
Blackpony's Avatar
Naa the wiring is really easy. Check out lt1 swap it makes things much easier. I have about 8 hours in mine thus far and I'm almost done
Old 02-26-2013, 01:50 PM
DougThorley's Avatar
You guys just let me know when you are ready for headers and I can get you all set up. We have specific sets for the c10 swaps.
Nick
Old 02-26-2013, 05:06 PM
sweetk30's Avatar
yep was it you guys that teamed up with us over at ck5.com for a test truck with ls swap to start making them ?
i read up on the project and was glad to see someone step up and ask for a real vehicle so we didnt get the typical 4x4 header hits the shackle bolts problem .
Old 02-26-2013, 06:13 PM
Blackpony's Avatar
Send me a price and info on them. I was planning to use ls3 Camaro manifolds but might try and swing some headers.
Old 02-26-2013, 07:57 PM
sweetk30's Avatar
you did read my build and know 10 min of work makes truck manifolds and down pipe fit super easy if no headers are in your plans.
Old 02-26-2013, 08:15 PM
LSx '85 C10's Avatar
I've got a mostly smooth truck intake if you want it. and what motor are you using? looks great with the krinkle paint, also Shoenfeld makes headers for the C10 swaps I'm using them on mine 3/8 flange with 1 3/4 primaries
Old 02-26-2013, 08:23 PM
Blackpony's Avatar
Yeah I was originally planning truck manifolds but got these free with the flanges and o2 bungs and I know they will fit with 0 issues. Guy I work with did this swap and used 2010 Camaro shorties.
Thanks ill check those out also. I'd like to do headers as my heads are getting extensively ported and a cam will happen soon. Oh and I am almost done smoothing my intake. Been thinking about going with the edlebrock truck intake
Old 02-26-2013, 10:00 PM
Blackpony's Avatar
Oh and the motor will consist of
5.7 Ls1 block
Bored .008 over with arp rod bolts, balanced crank, clevite h bearings
241 heads that have been extensively ported and milled .040 stock valves
Stock f-body cam for now
Truck intake that has been smoothed
Ported stock truck dbw tb
Ls6 maf
2010 Camaro manifolds
Ls7 lifters
Comp pushrods
3" exhaust with flow master mufflers
Old 02-26-2013, 10:12 PM
I miss spelled the header companies name it's Schoenfeld. They're pretty cheap too, only like 300 bucks. waht'd you use to smooth your intake?
Old 02-26-2013, 10:19 PM
Blackpony's Avatar
Started with a cutoff wheel to rid of the large stuff. Then I hit it with a 36 grit sanding disc on an angle grinder. Then 120 grit on the grinder and ill finish with a roloc disc. I am almost ready to start with the roloc. Once that is done ill use some filler primer, sand it with 400 then 600 grit paper and shoot some black semi gloss engine enamel. Hoping it looks good once done, ill have around 2-3 hours in it once done.
Blackpony's Avatar
The wiring pics show kinda where I'm at.
Quick Reply: Project ls swap c10 *update post 48*
