Drilling LS2 water pump?
I want to drill my 06 GTO Ls2 water pump, and connect a a 1/8npt to 4an 90 degree fitting. The fitting will fit right under my throttle cable wheel and face backwards. I plan on venting all 4 lines on head to the kurt urban box and then 1 4an line back to the fitting on the pump. Does this setup sound like it will vent ok, and is the ls2 pump thick enough to install the fitting just past where the upper hose fitting stops? Thanks for the help!
