LQ4/T56/HX55 Turbo Into 1986 El Camino.. Running Now
#141
I have the transmission sold out of the car.. Going with a 4L80... I'm going full build this time through so it will be a while before it sees the light of day again.. Frame has been tweaked so I'm having that straightened. going to narrow rear to fit some 315s. putting interior completely stock with gauges hidden in the ashtray from an El camino.
Engine pieces are being sold off.. if anyone needs anything find my add in the sales section
New combo.. 6.0 block.. flat top pistons.. gen IV4.8 rods.. 4.8 crank.. square port heads.. Converting to L99 accessories.. Going to run a truck square port intake I think.. and add a front mount and maybe a snow kit.. as well as having a flex fuel sensor in the mix and an additional 255 on a hobbs switch..
Should be able to haze a set of tires pretty easily..
That is unless I decide to copy the AWD cutlass and do that..........
