LS1 3rd gen headers. Anybody use these?
I was searching around and found the Kooks headers and contemplating on letting a buddy make some but then I ran across these. Is anybody using them? Seems like a little bit on the cheap side, but I pissed away $250 before on dumb ****.
http://www.racinginnovationandsupply...der_p_189.html
i have a set on my car. The appear to have extra clearance in the bolt holes of the flange so you have to position the header on the head in the right spot. The bolts will not align it correctly. The driver side could tuck better as it leaver only 1/2" clearance for the fuel lines. The passenger side hangs 1.5" too low. For cheap swap headers they work. I have a temp transmission cross member hacked together, was waiting to install the headers to make one fit the exhaust.
