Notices
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
BMW e34 Touring LS1 swap (BMW 5 series wagon)
Old 04-05-2013, 06:22 PM
  #61
SWAGON's Avatar
When I did turbo M52 in my E34, I ran a Cometic .14 MLS and ARP 200 studs. I used a Garrett GT3076R turbo with the TRM manifold and blow through tuning package and was making 350 RWHP/tq at 15 lbs and then I upped it to 17 for about a year but never got it back on the dyno. I figured at that point, I was making about 375. It was a fun car but not enough. Sold that to build the current project
SWAGON is offline
Old 04-05-2013, 06:50 PM
  #62
vazfx16's Avatar
Sounds nice. Once I get this project sorted, I may add a turbo. I did a turbo on a Toyota 4age years and years ago
vazfx16 is offline
Old 04-05-2013, 06:51 PM
  #63
Is ever really enough tho?
jakeb is offline
Old 04-05-2013, 07:38 PM
  #64
Vaz are these gonna be solid mounts?
Mitch
flashgordon is offline
Old 04-06-2013, 07:40 AM
  #65
vazfx16's Avatar
Mitch
They are going to be mounted on hard rubber, with the option of softer compounds if I shake my teeth loose.
vazfx16 is offline
Old 04-06-2013, 11:40 PM
  #66
vazfx16's Avatar
Template for the motor mount.
Rough sketch of the motor mount concept.
Transferring lines from the mount template to the tubing. This is a great way to get more complex cuts transferred to tubing. If your cut needs to be something other than straight and square, this is the ticket.
Tacking up the mounts.
Motor Mounts. Almost done.
vazfx16 is offline
Old 04-07-2013, 09:48 PM
  #67
vazfx16's Avatar
Finishing up the motor mounts
Completed mounts
Clearing the steering box.
Passenger side mount.
Task Complete
vazfx16 is offline
Old 04-08-2013, 07:50 AM
  #68
Nice work.
Those complex cuts gave me some trouble at first—I ended up using a very similar method with a cereal box and scissors.
LQ4-E39 is offline
Old 04-08-2013, 06:27 PM
  #69
Welds look cold to me. Subscribing This should be fun
Jimbo1367 is offline
Old 04-08-2013, 08:41 PM
  #70
vazfx16's Avatar
LOL. Which ones are cold welds, and how are you determining that? I will give a couple secondary welds (over the original weld) might be fat/cold, but all critical welds are hot and double filled if needed. Maybe some porosity in a few, but not enough to worry me.
I did a rough looking stitch welds on the plate so that I didn't warp them, I jumped for spot to spot as I allowed cooling in the metal. Also wanted to balance out the pull on the metal to even out tension. So you really can't go by the pictures since there is overlap and not a smooth continuous MIG bead.
One other thing, I have just learned how to take better photos of welds. Up until this weekend all my weld photos looked bad no matter how good the weld was. Notice the close up images were from my use of the Macro feature of my camera with the flash. The others without flash and slow shutter speed with wide aperture resulted in some terrible looking weld images. If you saw the welds in real life you might have a different opinion.
Peace
vazfx16 is offline
Old 04-09-2013, 09:52 PM
  #71
Great Build! I love the touring car, BTW are those hockey pucks you're using for your mounts? Friend of mine uses them for the lift on his jeep I thought he was nuts but they have worked well for 2 years of HARD wheeling
hrdrckclmr is offline
Old 04-09-2013, 11:34 PM
  #72
vazfx16's Avatar
those are vulcanized rubber disks...yes hockey pucks
vazfx16 is offline
Old 04-13-2013, 08:16 PM
  #73
vazfx16's Avatar
Trans mounts done
Trans mount mounted. Checking out and evaluating driveshaft options.
vazfx16 is offline
Old 04-13-2013, 08:20 PM
  #74
vazfx16's Avatar
Next headers or exhaust manifold. I think I can fit long tube headers. The driver-side is very tight, but I may be able to make it work. We shall see.
vazfx16 is offline
Old 04-14-2013, 02:19 AM
  #75
Great progress! Project is moving along nicely. Keep up the good work!
Teaguer is offline
Old 04-14-2013, 09:00 AM
  #76
vazfx16's Avatar
Thanks. Trying to keep rolling along.
vazfx16 is offline
Old 04-14-2013, 09:57 AM
  #77
Can't wait to see how the headers come together.
kesslerbmw is offline
Old 04-14-2013, 10:42 AM
  #78
Wow. Awsome DIY talent. Looking forward to seeing what you're gonna do with that exhaust.
Old 04-14-2013, 08:36 PM
  #79
vazfx16's Avatar
Working out header spacing with my more high-tech tools
vazfx16 is offline
Old 04-14-2013, 08:43 PM
  #80
vazfx16's Avatar
Thanks Flash. I maybe able to make the long-tubes work. The biggest issue now seems to be once I get them on, will I have to remove the engine to get them off.
vazfx16 is offline
Quick Reply: BMW e34 Touring LS1 swap (BMW 5 series wagon)
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
