Air Inlet Temps are High
Old 05-04-2013, 12:15 PM
badazz81z28's Avatar
Default Air Inlet Temps are High
It appears since my Spectre cold air intake tube is metal, it's getting hot thus increasing inlet temps. What can I do to cool them down? Some sort of wrap?
Old 05-04-2013, 01:25 PM
gofastwclass's Avatar
Have you monitored the air inlet temp or are you talking hot to touch? Are you picking up air from under the hood or is it a true cold air setup?
Old 05-04-2013, 03:03 PM
V8Rumble's Avatar
Yeah, I've considered this possibility. Figured that I'd do something to insulate the intake tube from the engine heat, as well as from the heat coming off the radiator. Guess I'll just have to see if I can find someone with a bit of header wrap left that they'll sell, or see how much sheet aluminum I have left when I get to that point...
Old 05-04-2013, 04:07 PM
It's a true Spectre cold air set-up with a enclosed sealing area from the engine. Monitoring it with HP tuners, I can see temps in 120s when its only 90 or so deg outside.
Old 05-04-2013, 04:18 PM
-TheBandit-'s Avatar
Where is the air coming from to feed the filter.? Did you cut a hole through the radiator support? Maybe you're just trapping hot air around your filter from the radiator end cap. Do you have a thermocouple or infrared probe you could use to monitor temps around the filter?
Old 05-04-2013, 05:53 PM
Old Geezer's Avatar
Is that MAF a 5 wire w/ the AIT in it? If so, blowing hot fan wash on it is creating a false AIT reading....
Old 05-04-2013, 08:05 PM
i r teh noobz's Avatar
I'd wrap the tube and get a standalone IAT before I started building a new intake.
Old 05-05-2013, 11:51 AM
69face's Avatar
I had a little newer motor, but here is what my setup looked like before i sold the engine. Iats went down to cold from hot. The turbulence of the engine sucking in air and the mixture of the air coming in cools closer to the throttle body. hope it helps a bit. good luck
Old 05-05-2013, 01:02 PM
Yes, It's a 5 pin 85mm MAF.
Quick Reply: Air Inlet Temps are High
