wiring autometer gauges
I did a 5.3/4l60e (out of 01 tahoe) swap in my 68' c10 , and am now trying to get my auto meter gauges wired up. I have the phantom series gauges. All electronic.
Speedometer
Tachometer
Oil pressure
Water temp
And fuel (wired and actually works) lol
I don't really have any experience with doing this and just kinda figured out the fuel gauge, call it dumb luck.
Are there any write ups on this? I have searched and not found anything.
Any help will be GREATLY appreciated!
Thank you
Speedometer
Tachometer
Oil pressure
Water temp
Thank you
they're pretty simple really. The speedo will get power and ground, then the speed signal will come from the PCM. Same for the tach, power, ground and RPM signal from the PCM. The oil you'll need to use the sender that came with the gauges, you can either use the factory location behind the intake or drill and tap the iol bypass block above the oil filter. Behind the intake will require an adapter, but you can make one out of the original sender by breaking off the plastic part and drilling and tapping the aluminum part to fit your Autometer sender. The volt meter will just be an ignition hot wire and a ground.
Also I have a water temp gauge, not a volt meter, will it replace the stock or will I have to "make it fit" like the oil pressure sending unit?
And you are exactly who I had hoped would reply, I have read alot of your other posts and seems to be that you know your stuff.
Thank you again
Joshua
I guess i spaced off the water temp sensor and was thinking voltmeter. Anyway, Autometer has an adapter for the temp sender, so you shouldn't need to modify anything on it.
The pins for the speedo and tach are:
Speedometer - C2 (red connector) pin #50 Dark green/white wire
Tach - C2 pin #10 white wire
search for the "pinout" locations on the red/ blue pcm connectors
I usually use the Autometer adapters for the sending units, both oil press (back of intake/ top of block) and temp in cylinder head
Got everything wired up, and everything works. I got the speedo calibrated.
My only issue is that my tach almost vibrates (bounces really fast) when at idle and any other rpm it's smooth as glass, except at idle?
Any ideas?
Any ideas?
Andrew
Im having a weird transmission issue ever since I got the gauges finished. and I am wondering if it could be related.
http://www.performancetrucks.net/for...3/#post5105258
Any ideas?
thank you
Any ideas?
thank you
Any ideas?
thank you
Any ideas?
thank you
Got a new speedo as the old one wouldnt take the signal from the PCM.
and now Im having issues with the new speedo.
http://www.autometer.com/download_in...164-00rB-2.pdf
Those are my instructions.
I must have something wired wrong is all I can figure.
I calibrated it without the lights on today and got to 4k stopped hit trip and it was calibrated but the speed was WAY off, Im talking 40mph off. If that wasnt issue enough, when I drove it tonight and I turn my lights on it goes back to the stage like it has never been programmed where the pointer is below zero.
Turn my lights off and it works again just the speed is way wrong.
Its on a 68 c10 if that matters, 5.3/4l60e out of a 2001 tahoe.
Thanks for any guidance.
Joshua
Joshua
Joshua
Joshua
Andrew
Follow the directions in this video:
Andrew
Like I said, its been a while since I set mine up so I might be a little rusty on the details. But the factory PCM puts out 4000ppm when the tune is correct. Since Autometer speesometers are looking for a 2 mile calibration, you need to set it at 8000 pulses. If your tune is correct, the speedo will be right on the money. If your tune isn't exactly correct you can adjust the speedo from there. Its true that rear end gear and tire size will affect the speedo, but if your tune is way off, then so will your shift points, so it needs to be set pretty close.
Andrew
The question is: is your speedo reading your actual speed accurately?
When I did my calibration, using the ABS sensor, I verified my speed with the GPS on my phone.
Are you sure that your speedo is displaying actual ground speed?
Andrew
