ls doge magnum swap completed.
Old 02-26-2015, 01:46 PM
2006magss's Avatar
Default Magnum swap
Did you have any problems with the a/c going from can bus to analog
Old 06-08-2015, 09:14 PM
dt23400's Avatar
is this guy still around? i would like to speak with him.
Old 11-18-2015, 04:26 PM
Zae Jones's Avatar
Originally Posted by s/clsxmagnum
I have heard a lot of people asking if it could be done. Here is mine. Completed for now... always improving. Currently doing a/c.
Ok I'm having trouble how did you do the transmission mounts and the engine mounts could you show me more pics please
Old 11-23-2015, 05:37 AM
Zae Jones's Avatar
Thanks for the pics I have to figure out the transmissio cross member now
Old 11-23-2015, 05:39 AM
Zae Jones's Avatar
And how did you your drive shaft
Old 05-09-2018, 09:25 PM
Mikey Williams's Avatar
Default Can you make more
Can you make more of the mounts and how much to send to las vegas nv
Old 05-09-2018, 09:39 PM
Received 3,017 Likes on 2,348 Posts
2-1/2 yr-old post.... don't hold your breath.....
Old 10-31-2018, 08:29 AM
Fosie's Avatar
Default Dodge Magnum LS Swap
Hello , I was wondering who has done a LS Swap in a Dodge Magnum ? I know I've got to build motor mounts and will use a low profile oil pan , Does the oil pan sit down below all the steering stuff or does it set up above the steering, And does anyone have any pics showing how the motor sits in there
Thank you
Quick Reply: ls doge magnum swap completed.
