Torque output
Torque output
Ok new too the site the only ls I have currently is the 4.8 in my 04 silverado and I love it. Now on to my question. First off my toy is a 41 chevy pickup that was subframed many years ago with a salvaged 79 ws6 trans am. It has every drive train component that would fit motor trans posi rear 4 wheel disk and the infamous 403 olds. While this one was well built and is the reason it was salvaged for the truck, it is loosing oil pressure and my heart transplant will be an ls. I plan to go carbed and plan on an salvage lq4. Can this motor be built to have similar low end torque output compared to the 403 ? Cause it pulls hard even with 2.73 gears. What cam would be a good choice ?
I know these engines are different animals and it won't be exactly the same I just wondered if I could still have some off idle tire burning torque. My 4.8 doesn't wake up till about 4 grand
Ur 4.8 is probly drive by wire which gives a really dissconneted feel which doesn't help plus a stock cam. But with ls style motors you get the down low with out giving up top end
Ya my 4.8 dbw and I know the torque management has a lot to do with it also, I've never driven an ls without it so I don't know how they feel. And yes I've researched cam choices and combos but it seems like all of them recommend running at least a 3 grand stall. I wanna drive it a lot and a 3 grand stall is a pain , I wouldn't mind maybe a 2000 rpm stall. Ill be running a 350 turbo for now and the 2.73 gears until i get overdrive .I want the power band to start early even if it doesn't pull to 7000
I know the cams with high lift and lower duration make the most torque but I would like to keep it around .550 on lift to make my valve springs last closest thing I've seen lookin at dyno charts was a reverse split any experience with those?
Plan on running a 350 turbo for now and I'm not against changing the rear when I do get an overdrive but for now it makes helps me cruise at a reasonable rpm with a 3 speed
So I found a complete running 5.3 for 300 dollars is it worth getting so I can get my engine bay set up for an ls, motor mounts ,get headers to fit ,wiring etc and run it for awhile so I can build the 6.0 like i want l92 heads with a lightweight valvetrain and stroke it to a 403 lol. From what I read a .005 hone and a 4 inch stroke comes out roughly to a 403 on a 6 liter
300 is a good price if its complete. Perhaps you should consider a mild cam for the 5.3? Hop it up just a little and build a killer engine on the side.
My 5.3 will shred tires at any RPM, even with a cam that doesn't wake up till 3000 RPM. I do have a manual trans and 3.70 gears though.
Unless you have a dual pattern TH350 that BOP pattern trans isn't going to mate up with the LS motor. Update the trans now and get it over with you won't regret it. E-shift trans and OD will make more of a driveability difference than going from a 403 to a LS motor.
I went mild 403 -> stock 6.0. More power, better mileage, front end came up an inch. Biggest regret was keeping the 4L80e and not going to a 6Lxx trans.
403 was a great motor *for it's day*
Ok I found my mistake on the transmission controller price,the one I was looking at came with a paddle shifter tcu from tci or b&m runs around 600 dollars so what would be the benefits of the electronic controlled tranny vs the 700r4 both of them being performance built
$600 for trans controller, $600? for MSD box and carb intake (no carb), you're getting to the price of a complete 5.3 cutout with trans, harness, PCM in some areas.
Maybe contact PatG? He gets alot of referrals around here. A smaller custom cam and some LS6 valve springs would be worth a look.
