1941 plymouth 5.3 swap. Need c1, c3, c4 fuse box connector pinouts
Old 08-20-2013, 04:03 PM
redlinerestoration's Avatar
Default 1941 plymouth 5.3 swap. Need c1, c3, c4 fuse box connector pinouts
We are using the 5.3 engine, trans, harness, accessories and all from a 2001 Chevy 1500 in a 1941 plymouth business coupe. I need to see if anyone has the pinout for this fuse box, connectors c1, c3, and c4. I have searched all over ls1 tech, and google in general and have been unable to find these. I have found 03 up diagrams with no issue, but the pinouts and wire colors are incorrect. Someone please help with this if possible. If you have the diagrams, you can email them to me at redlinerestoration@gmail.com
Thanks
Chris
Old 08-20-2013, 08:49 PM
ls1nova71's Avatar
LT1swap.com should have them.
Old 08-21-2013, 09:14 AM
lt1swap.com does not have them. They have listed the "4 wires needed to make it run". I want the full pinouts for the whole junction block, as I am going to be using the rest to power the car.
I even sent the owner and email and haven't gotten a reply.
Old 08-21-2013, 10:30 AM
goodwrenchbutch's Avatar
you should have an email. I don't know if the connector pics will show up but the terminal locations should be there. I hope this works.
later Goodwrenchbutch
Old 08-21-2013, 10:52 AM
Thank you sir!
Old 08-21-2013, 02:38 PM
I'll pulled it all labeled and sorted, and everything looks good except for the c4 plug. none of the wiring colors or pin positions matches what I have. Any other ideas?
Quick Reply: 1941 plymouth 5.3 swap. Need c1, c3, c4 fuse box connector pinouts
