builk head connectors
Why not just drill hole and use a rubber grommet?
Either way there will be a hole. So might as well save yourself the headache of crimping all those wires from a harness to a bulkhead connector and then crimping all the wires for the other side of the bulkhead connector.
Only advantage I see of doing it would be for quick and easy motor removal. You could dissconnect from the fire wall and leave harness intact on engine and just lift it out.
Ive seen Deutsh HD30 series connectors used for this. Nice components for the price
http://www.wirecare.com/deutsch-conn...D30&contacts=6
If there was any good available spot on my firewall I would have went this router over a grommet.
Maybe whenever I do A/C delete plate and vintage air I'll have a spot for it.
My luck, water will find a way in which I don't want since it'll be sitting out in the weather. Also my luck if I had an engine fire, I want it in the engine compartment, not smoldering on the insulation in the car to burst in flames later Just my personal preference to use a bulkhead when I can.
Here is a good looking Deutsch AutoSport http://www.wirecare.com/deutsch-conn...AS&contacts=13
Raychem Heatshrinkable Boots at the bottom of the page
http://d2kmxso4hn1htz.cloudfront.net...2K121-25-0.jpg
The Duetsch AS bulkheads ARE aluminum.
According to there page,Material Specs
Shell / coupling ring: High strength aluminium alloy with a conductive black zinc finish**
Contacts:Gold plated crimp contacts*
Insulators: Thermoplastic
Interface / wire seals: Fluorinated silicone.
* Except hermetic connectors
** Except hermetic and ASC connectors
