Ls1 conv whole bank not firing?
As title suggests, putting a ls1 into Aussie nissan patrol. Engine fired up fine, could tell it wasn't right. But the whole 4 cylinders on the passenger side aren't firing. The pipes are Luke warm to the touch and when ign is on there is no power to the coil(s)
Any ideas? I've missed something but not sure what. Thanks in advance
Zappa
Zappa
I only have fusses on the ign and power feeds into the ecu. I went and checked and although I haven't got a noid light, with a stethoscope it appears the inj aren't working either. There was also no continuity to earth on the indi coil conn?
Yep, check the grounds. Each bank has its own ground wire that ties in at some point. It is the black wire from each main connector(2). As stated it could also be the supply voltage. You now have your homework assignment.
