86 regal 5.3/4l60e shaking at higher speeds
Around 60-75 mph the car starts shaking. Almost has the feeling of hopping and swaying. The front feels fine, nothing through the steering wheel it all feels like it's behind me.
I'm not even sure where to start. I plan on getting new rear tires soon but I'm just not sure that has anything to do with it.
Any ideas on where I should start troubleshooting?
sounds like it could be the rear tires, miss aligned rear end or possibly a drive shaft issue if you think it is behind you. If they fit you could try swapping the front and rear tires and see if the shake fallows. Good luck.
Check the wheels for weights, sometimes they fall off the rim if not clamped on there properly. More info. will help too: Car lowered? (if so, what method did you use?), what brand and size are the wheels and tires? How old are the tires? Wheels lug or hub centric?
Get under the car and torque every bolt you can get a wrench on. Especially drive shaft bolts. Check tire pressures too. Look for worn U joints.
Beyond that it is most likely tires, but if that doesn't work here is a good reference.
http://www.aa1car.com/library/vibrations.htm
One thing I have found if I don't drive the car for a period of weeks/months the tires tend to flat spot making the whole car shimmy. The fix for that is to just drive the **** out of them for awhile.
The only thing that seems to be constant about it is the speed it starts shaking at, and that's somewhere right above 60mph.
