F-Body Cooling Fan 3-Relay Question
I've searched and read threads about cooling fan relays till I'm blue in the face.
Based on my findings, my understanding is that the 2002 f-body dual fan set-up used three relays and had both fans running at low speed for the low temp signal and both fans running at high speed for the high temp signal.
I found the wiring diagram that many say they used to wire three relays up in this fashion.
My question is:
Does anyone offer a pre-wired 3-relay harness that matches this fan functionality as I just described?
Thanks.
My question is:
Thanks.
I do not have AC however I do want the fans to operate as noted in the original post. I'm comfortable wiring although I have never worked with relays. I'm not sure what type I need in order to achieve the functionality that I want. I've also heard that I need special relays that will protect the ECM from voltage spikes...is that correct?
A relay is just an electro-magnet. Very simple.
Buy what most consider a "bosch" 5 terminal relay and pigtail. Terminals 30, 85, 86, 87 and 87a. IIRC you NEED the 87a terminal on the relay, some do not have it.
30 = source of power (usually) OR ground
85 and 86 are power and ground. You can use either for a trigger.
87a = the output of terminal 30 when the relay is NOT triggered.
87 = the output of terminal 30 when the relay IS triggered.
Its not hard to make a harness for the Relay and Fans.. just get the relays, pigtails, some wire and connectors.. If you have a source to buy the parts or you can go to the Junk Yards and just rip out a setup or parts.
I used some spare relays and pigtails from the Camaro that I parted out.. Work just like OEM. You can even use a JY fuse box w/relays.
BC
BC
My question is:
Thanks.
My question is:
Thanks.
http://www.racetronix.biz/itemdesc.a...%2D006&eq=&Tp=
T,
Exactly what I was looking for.
Thanks.
I appreciate the input from everybody else as well.
Here is a 3 relay setup I found on Ebay. I was thinking about ordering since its only $69.00. Looks like a nice set up.
http://www.ebay.com/itm/151134100961...84.m1423.l2661
LS1TECH Sponsor
HP fans (i.e. SPAL) require 10G wire b/c they draw much current. 12G is OK for factory fans but there is still a considerable performance hit. Our harness is 100% weatherproof and easier to hide. If you want max fan performance and best possible reliability our FNWH-006 is the way to go. We offer a lifetime warranty on this harness.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
You offering any specials for LS1 Tech members? This definitely looks like the best harness option I have seen.
LS1TECH Sponsor
http://racetronix.biz/itemdesc.asp?ic=FNWH-006&eq=&Tp=
Free t-shirt using coupon code FREE-SHIRT on orders over $100.00 (less SH)
http://racetronix.biz/items.asp?Cc=PROMO&Bc=
__________________
>WEB SITE<
>WEB SITE<
