G Body LQ4 with 4L80E - Rear Gear Ratio Recommendations?
Old 12-05-2013, 06:55 AM
Docked Wage's Avatar
Default G Body LQ4 with 4L80E - Rear Gear Ratio Recommendations?
Motor is a cam only (TSP 224) and Trans has a Circle D 3000 stall. Other than that it's stock.
I'm looking at a complete rear end that has 4.10 gears. Is this too much gear for a street car? I might take it to the track once a year.
Thanks, Ken
Old 12-05-2013, 08:59 AM
1964SS's Avatar
What size tire are you running? How much of a street car is it?
Old 12-05-2013, 09:25 AM
Thanks for the reply.
Tires are 27" diameter.
It's 99% street. More putting around from light to light. Some freeway. I'm not a little old lady but more and more I'm driving like one. I still like the acceleration though on occasion. Lots of straight smooth roads here.
Ken
Old 12-05-2013, 09:35 AM
bczee's Avatar
Might suggest 3.73:1.....
Old 12-05-2013, 09:42 AM
1964SS's Avatar
52mph @ 2000 rpm
65mph @ 2500 rpm
78mph @ 3000 rpm
It will be streetable and fun, but your mileage will not be very good. These numbers will probably be a bit higher with your converter also.
Here's a calculator you can play around with.
http://www.wallaceracing.com/gear-speed.php
Old 12-05-2013, 10:15 AM
Thanks Guys!
I'll mess with the calculator tonite.
I was predisposed to the 3.42 or 3.73 but figured I'd ask about the 4.10 since it's a decent deal.
Old 12-05-2013, 09:17 PM
spacemanspif's Avatar
Running similar tire size on my Monte. With factory 3.73s at 65ish I'm close to 3k rpm. For a street car I'd go with 3.42s, so that you have good street manners and mpgs. The 80 has a shorter OD than the 60 so go with a taller rear gear. Plus with a 3k stall and all the torque of the LQ4 the difference between 3.73 and 3.42 won't be very noticeable.
Old 12-06-2013, 04:43 AM
1970camaroRS's Avatar
My Cutlass is getting a LQ4/4L80E with a 3,000 stall also with a 27" tire. 226/232 on a 115 cam. Having a 3.42 8.5" delivered on Monday. This is going to be my daily driver. 3.73 would also be a good option, but turning 2400rpm at 75mph is hard to say no to. The 3000 stall and 3.42 gear will work well with the mild cam too. Not perfect, but it will work.
Old 12-06-2013, 07:46 AM
Thanks guys. This is exactly the feedback I needed.
Ken
Old 12-06-2013, 07:49 AM
Nathan,
Can you help me understand your cam selection?
Ken
Old 01-06-2014, 03:16 AM
Originally Posted by Docked Wage
Nathan,
Ken
I missed this reply. The cam I'm using is for a turbo build that got put on the back burner. Mild idle, plenty of vac. Should make for a decent cam-only stock head engine.
Quick Reply: G Body LQ4 with 4L80E - Rear Gear Ratio Recommendations?
