New Hooker 1st-gen/Nova swap parts info
#62
I've been trying to get to it for a couple of days, but the management uppity-ups have found ways to repeatedly divert my efforts onto other things this week. The car will be leaving at the end of next week and I will find time between Monday and Friday to check it for you; I just can't say exactly when I'll be able to slip it in. Any particular place you want me to check? At the throttle body?
#65
#66
I can definitely relate to how that goes. At the throttle body would be a great point, and also at any hood cross braces that may get in the way. I haven't gotten far enough to figure out where any trouble areas may be yet, so I'm going to trust your judgment on where you think of to check. Thanks again!
#67
I've just confirmed that the truck intake/throttle body without the dress cover clears a closed hood when sitting on an LS installed with the new Hooker 12618HKR engine bracket kit. With the cover I have here there is interference between the cover and the X-brace under the hood. I hope this help you out.
You are the man. Thank you so much for checking on this! I don't care about the cover... so hopefully mine clears too!
#68
I am really happy to have found this thread and hopefully the rep from Holley is still monitoring new posts.
I am looking for a complete package to install in my 69 camaro. Currently the car is a full on project and the Suspension and underside of the car is 100%. I am looking to install an LS3 and T56 Magnum. I have a list of part numbers that should work but i have a few questions because of a semi unique steering setup.
1. I am running the ride tech TruTurn steering system. There is a little bit of extra tie rod clearance needed with this system. Is it possible to get a dimension using the 302-2 pan from the drag link to the face of the oil pan sump? If there is not enough clearance with this pan is it possible to use the 302-1 pan?
2. Do you have any cad/solid works or any other dimensioned type drawing so i can use my own measuring to determine what will work and what won't?
3. How much clearance is there between your header tubes and the tie rod ends all the way thru the steering cycle in both directions?
#69
I do have CAD drawings of our components, but they are protected intellectual property and not something I have the liberty of being able to share with persons outside of the company.
I'll dig up the photos that I have and post them up this morning.
Todd
#70
These three images should tell you quite a bit about your question...the top image shows the relationship between the stock steering components and the Holley 302-2 oil pan and Hooker headers and the images below it show that clearance of the same components locked in a full right turn and full left turn respectively.
#72
The 302-1 pan could be used with the new Hooker mounts by either notching the front engine crossmember, or by reducing the height of the front profile of the pan.
#75
I know the answer to this will not be very specific because of integrating another brand of motor mounts but here goes.
What about using a mount such as the dingo slider. It will allow the engine to be pushed a bit further back toward the firewall. I wonder if this will give enough clearance to pass the TruTurn. Also moving the engine back will push the trans mount back, is there enough adjustment there? What about header to firewall or tie rod clearance.
#76
#77
Looks like the MAST motorsports pan might be the way to go. Or at least the best option. I have been looking at the dimensions of every pan that I'm aware of on the market.
Mast
Autokraft
ATS
Stock GM
Holley
Etc
Mast seems that it will still fit with the stock front crossmemeber with about 1/4" to spare. Also looks like its sump is the furthest back and will allow the best chance for tie rod clearance.
Mast
Autokraft
ATS
Stock GM
Holley
Etc
#78
Todd.. just mounted my 302-2 on my LS1 for my Chevelle.. Only two issue was as follows:
1) trying to mount the second bolt on the pickup to oil pump. I ended up using hex headed bolts. As stated before on this or some other thread. Hard to use a bolt and socket/wrench to secure the bolt for the pickup with the front cover on. Suggest you supply the correct bolts to make it easier to install the pickup tube.
2) Black plastic cover on the Driver side near the oil filter, using the F-Body covers. I had to trim the plastic for the cover to sit flat. Might just put a commend on the Installation Instructions.
Both are somewhat minor. But I thought I let you know and maybe the Research Dept can come up with a good solution and packaging.
I'll get the engine back in soon and check the clearance of the pan to steering and cross member. But right now I also have just took the Nova out for its first road test !... so I am trying to work on to projects at the same time.. !
BC
BC
#79
BC
BC
#80
Mast
Autokraft
ATS
Stock GM
Holley
Etc
Mast
Autokraft
ATS
Stock GM
Holley
Etc
