2010 Camaro 6L80 Swap
Old 12-26-2013, 04:48 PM
mrttype's Avatar
Default 2010 Camaro 6L80 Swap
I doing a 6L80 swap from a 2010 Camaro into a 70 Chevelle. Where do get a speed signal for a Dakota Digital speedometer?
Old 12-26-2013, 05:50 PM
1989GTA's Avatar
You are not alone with this problem. I am going to use a Speedhut speedometer that uses the signal from the GMLAN communication wires. Maybe Dakota Digital now does the same thing. Some are experimenting with pin J1-57 on the E38 ECM. That may or may not work. The signal may have to activated in the software using something like HP Tuners.
Old 12-27-2013, 02:22 AM
rsz288's Avatar
Pin 57 can normally be turned "on" with the right tuning software. The Camaro does not use this pin from the factory.
Old 12-27-2013, 07:57 AM
mrttype's Avatar
So the TCM sends the signal to the ECM over GMLAN? Does the TCM need that turned on in their software?
Old 12-27-2013, 08:02 AM
rsz288's Avatar
The TCM broadcasts the speed over the CAN/GMLAN by default. Normally a matter of turning pin 57 on in the ECM, though plenty of variations from GM of course .
Old 07-01-2014, 06:26 PM
Hart_Rod's Avatar
HPTUNERS -> Speedometer -> General -> Speed output type -> vehserial
Quick Reply: 2010 Camaro 6L80 Swap
