lq4 6.0 in a 63 nova with a procharger have a few???
Old 01-02-2014, 09:50 PM
1bd63nova's Avatar
Default lq4 6.0 in a 63 nova with a procharger have a few???
so im buliding a 6.0 in a nova with a f1r pro charger lsx intake fast rails trick flow 220 heads comp blower cam and a set of 2 in lemon headers
the questions are what should i use for a drive by wire throttle body?
also do you guys run normal an fittings for fuel from the pump?
Old 01-02-2014, 09:56 PM
1bd63nova's Avatar
heres the car
Attached Thumbnails lq4 6.0 in a 63 nova with a procharger have a  few???-photo-4.jpg
Old 01-03-2014, 04:27 PM
Hotrodnova66's Avatar
Your throttle body and gas pedal have to match in order to work. As far as fuel system in my nova with my ls2 I used a1000 fuel pump with -6 line from the pump to the fuel rail, they sell an an adapter to push on the end of the fuel rail with an fitting on the other side.
I see a lot of other people using like 5/16" or 3/8" hard fuel line from pump to fuel rail also, guess it really depends on what you like and how much you want to spend.
Old 01-03-2014, 04:35 PM
Jimbo1367's Avatar
Nice car. I prefer DBW for cleaner looks. Yes, normal AN fittings. Some people have fuel smell using normal AN hose. Some sort of PTFE line hose is best. SUMMIT and Jegs both have house brand "premium" hose thats E85 friendly and won't give off fuel smell.
Being Procharged, I'd go -10 supply/ -6 return.Try a SEARCH
Old 01-04-2014, 07:56 PM
1bd63nova's Avatar
thanks for the info im looking into a maganafuel pump and a boost references regulator.
Old 01-04-2014, 08:07 PM
Doug G's Avatar
-8 or -10
Your call on DBW or DBC.
Buddy has a BBC in a 64? and a Y? trim...Holy
Quick Reply: lq4 6.0 in a 63 nova with a procharger have a few???
