How to release the sensor at the PS rear of 6L80 ?
Old 01-18-2014, 09:39 PM
AKtundra's Avatar
Default How to release the sensor at the PS rear of 6L80 ?
Trying to seperate a 6L80E and not sure how to remove the sensor in the rear
Twist? Pinch?
Might have to down load the app to post a pic
Old 01-18-2014, 09:55 PM
i r teh noobz's Avatar
We need a picture, or at least a better description. What sensor is it?
Old 01-18-2014, 09:59 PM
BigEd_72455's Avatar
I would have to guess he is referring to speedo output??
Old 01-18-2014, 10:14 PM
69face's Avatar
Main plug is twist the locking ring and pull. the others are dummy proof, so I'm positive you aren't referring to them.
Old 01-18-2014, 11:01 PM
AKtundra's Avatar
Thanks 69, that got it. There was some kind of stamped piece, maybe a heat shield, that was keeping the tab from twisting
Trying to get this engine on the stand, suppose i can hi-jack my own thread. Moving on to the torque converter, that is released by the 3 bolts on the backside of the flywheel?
Old 01-18-2014, 11:03 PM
yup, remove the starter and motor mount on passenger side of motor for easiest access. You can use a long extension and impact to just zip them right out
Quick Reply: How to release the sensor at the PS rear of 6L80 ?
