1990 300ZX - Built LQ9
Old 02-06-2014, 11:27 AM
SuperHatch's Avatar
Default 1990 300ZX - Built LQ9
Purchased a junkyard 6.0L LQ9 to start with. Put together a package working with Andrew from Complete Street Performance.
And, the shopping commenced...
Bottom End:
Sealed Power 0.020" over flat top pistons
Sealed Power Rings
ARP Rod Bolts
ARP Main Studs
SLP Double Roller Timing Chain and High Flow Oil Pump
ATI Underdrive Damper
ARP Damper Bolt
Lunati Custom Grind Cam
New OEM Lifters
LS6 Valley Cover
New Gaskets/seals/etc
Top End:
Sent the 317 heads to Advance Induction for a full CNC Port treatment, as well as combustion chamber welding and reshaping to 243 specs (C5 Z06)
Manley Nextek dual Valvesprings
Ti Retainers, Hardened spring seats, Hardened locks, Viton Valve Seals
New Stock Rockers with Comp Cams Trunnion Bearing Upgrade
Hardened Pushrods
OEM MLS Headgaskets
ARP Head Studs
Target CR of 11.5:1
Fast 102 Intake Manifold
Fast 102mm Throttle Body
Fast Injectors
Time for some gratuitous Pics:
Heads before sending them out:
Block before any work: (In pretty bad shape)
Fast Injectors:
Lunati Cam:
Pictures of the parts at the machine shop the day they were dropped off.
Sealed Power Pistons and Rings:
Gaskets:
ARP Galore:
LS6 Lifter Tray/Valley Cover:
SLP Timing Chain and Pump:
ATI Damper:
Shipped the heads to AI:
Left all these parts at IDM Speed and Machine in Mayetta, NJ. IDM has treated me very well over the past 10+ years. Ed and Don really know what they're doing and I'd trust them with any job.
First order of business was washing and media blasting the block, it was then rough bored.
Then we got the heads back from AI:
Stopped back at IDM, dropped off the heads and checked out the status of the block. Block was torque plate honed to spec, getting ready for assembly...
Got some aftermarket valve covers:
Also got the new OEM rockers and Trunnion Upgrade Kit:
Stopped back at the machine shop yesterday. ARP mains were installed and block was line honed, ARP rod bolts installed and the big end of the rods were resized. Block has been painted, rotating assembly was installed, cam was degreed, and Piston to Valve clearances were checked. PTV it 0.201" with no head gaskets, OEM gaskets are 0.051" thick. That's healthy clearance, IDM considers 0.100" to be a minimum. The rest of the rotating assembly is going together today, should be picking up the engine either tomorrow or Monday.
Had an aluminum driveshaft made... Hardened steel input and output flanges, Spicer U-Joints, heat treated aluminum tube, fully balanced and 100% made in the USA. High quality parts here, none of the chinese crap some vendors sell. Rated to 750WHP in a 3500lb car on slicks.
In any event, that is where we are at for now. Once the motor is done the install can commence.
Old 02-06-2014, 07:07 PM
Verz's Avatar
Looks like some nice quality work being done all around, kudos on that. Noticed you didnt notch the firewall, any foreseeable hood clearance issues or did you lower the mounting location like a few others have?
Old 02-06-2014, 08:47 PM
SuperHatch's Avatar
Mounting locations are at stock height, using the Z transmission, so no need to notch the firewall, and the hood fits just fine Thanks for the Kudos!
Old 02-07-2014, 02:36 PM
vettewreck's Avatar
Old 02-07-2014, 03:27 PM
BigEd_72455's Avatar
That block all cleaned up is one sexy bitch!!
Best of luck on the build and hope the car holds the power well and keeps you going for a long time to come.
Old 02-07-2014, 04:55 PM
unicornhobo's Avatar
this looks like an extremely fun project.
Old 02-17-2014, 07:55 AM
SuperHatch's Avatar
Thanks guys!!!
Engine is all together. Going to be finishing up some details on the motor this week then it's time to tear the old motor out of the car!
[/QUOTE]
Old 02-17-2014, 09:23 AM
vettewreck's Avatar
I know its hard to say at the moment, but do you think the price tag of $900 for heads to AI is worth it? Do you like how they ported the heads in the runners and ect? Ive been debating. For just porting I can see $500-650 but $900 just seems steep.
Old 02-17-2014, 10:17 AM
SuperHatch's Avatar
I honestly can't say for sure. CNC porting is in a league above typical hand port jobs, but that comes at a price. We'll find out when it hits the dyno.
Old 08-17-2014, 09:20 PM
ranmas2004's Avatar
OK since first start is Saturday August 23rd Going to post an update. Finally got everything all together!
Old 08-17-2014, 11:51 PM
V8Rumble's Avatar
Thumbs up
Project looks great, that oughta be a HELL OF A LOT OF FUN!!
Originally Posted by ranmas2004
I'd forgotten about people mounting coils like that - that's a GREAT idea (& I'm going to shamelessly copy it)!!
Good luck on the startup!!
Old 08-18-2014, 06:06 AM
1slo5ohh's Avatar
Cars looking good man. I'm with Rumble on this one, I like the coil location and may just borrow that idea as well lol. Did you buy the brackets or make them your self?
Old 08-18-2014, 07:48 AM
Quantummechanic's Avatar
Nice!
Are those LOJ's headers?
And what rad did you go with?
Again, nice!
Old 08-19-2014, 11:07 AM
OEMTim's Avatar
Mark me down as someone who loves the coil idea and plans on adapting it to my next project! ;-)
Old 08-19-2014, 12:38 PM
SuperHatch's Avatar
The car will be an animal. We have a shop car, a 1993 convertible, with a stock LQ9... LS6 cam/springs, trailblazer manifolds, LS2 intake, 2.5" exhaust, and the car has trapped 110MPH with 3.13 gears. The verts weight nearly 300lbs more than this car.
I would expect this car to go well into the 10s with slicks and a good driver.
We made the brackets in house. They work great for this application, but are not compatible with our A/C bracket. This car doesn't have AC so that's a moot point.
Originally Posted by Quantummechanic
Nice!
Again, nice!
Those are Kooks headers for a TBSS, modified to fit in the Z. This build started before we partnered up with Kooks, so this is a bit of a 1-off. Our productio headers will be ready to ship early Sept.
Thanks!
Old 08-19-2014, 03:53 PM
Jay Gadsby's Avatar
Very nice! Looking forward to seeing it all done.
Old 08-24-2014, 07:00 AM
SuperHatch's Avatar
First start...
Old 08-24-2014, 09:01 AM
Benjamin Russick's Avatar
Very cool project and great work so far!
Old 08-24-2014, 02:50 PM
SuperHatch's Avatar
Thanks!
Old 08-24-2014, 05:13 PM
PT Nova's Avatar
Looking great! Like the look of the valve covers, where do you got them?
Quick Reply: 1990 300ZX - Built LQ9
