My 66 Impala 5.3 swap
#65
Unless the fuel rails are changed out for an aftermarket style, this style adapter is really the only option at the rails. On the filter/regulator, the end with the single port needs a push-in style short section of line with the properly flared end to connect the adapter to. There might be another push-in adapter that can be used, I don't know. On the other side, with two ports, the ends are already flared. To my knowledge, these adapters are the only option to connect these flared ends to AN line.
#66
JDUB66,
Gongrats dude!!! Great job!
#67
I need to purchase some myself and after some of the stories about the clip ons I'm thinking of buying these.
http://www.ebay.com/itm/131193346347...84.m1423.l2649
#68
Attachment 456472
Attachment 456472
#75
Stance is "Perfect"........Great Job!!!!
#76
Thank you Dave Nick and Whizz!!!!
Not too bad for a guy that never once in his life pulled an engine or took one apart. I am very pleased and owe a lot of my success to this forums.
Got some more to do the interior and eventually repaint the whole car and rims. But for now, I'm driving it for a couple years before i do paint, tho! Lol
#78
That's actually with the front down to tire touching wheel well and just enough height in the back to keep the tranny pan and exhaust from touching the ground. I do drive it a little higher than that on a couple roads by my house that are brand new, other than that normal height is a few inches higher overall.
#80
Update
Car ran great, managed to break a U joint rompng around in it (brand new U joint at that).
redid the rearend to 3.73's and disc brakes. Also have tubular upper and lowers up front and will be picking up a ported LS2 intake (102mm) tomorrow to run with my 102mm TB and LS2 injectors.
I also have a spare LS1 on the engine stand from a donor car I picked up a few weeks ago, looking for a good shell of a C10 to put that in.
Also I am amazed at the 7000 view of this thread. i'd bet a good majority of people got help and the others think I am an idiot, lol.
hope all is well with those that help me, you know who you are!
