Pure Automotive's FR-SS, Modified LS2 / T56 Swap, 2013 Scion FRS - Video Inside!
Old 03-14-2014, 08:08 PM
Pure Automotive's Avatar
Default Pure Automotive's FR-SS, Modified LS2 / T56 Swap, 2013 Scion FRS - Video Inside!
Hey guys,
We finally got our LS swapped 2013 Scion FRS started up yesterday, so I thought I'd share the video and some pictures!
The facts:
2013 Scion FRS
3,200 miles on chassis
LS2 From 2007 Cadillac CTS-V
T56 From 2006 Pontiac GTO
Dual ECU Setup: FRS ECU For All Required Functions on the chassis, tuned on ECUTEK Engine Management. CTS-V ECU For engine control, tuned on HP Tuners VCM Suite.
LSX-R Comp Cam
Comp Lifters, Push Rods, Trunions
GM Head Gaskets
ARP Head Studs
Dual Valve Springs, Titanium Retainers
Still have some odds and ends to iron out but it's getting close!
Startup Video:
Old 03-14-2014, 08:13 PM
Carguy8888's Avatar
Thats the way they should have come from Toyota lol. It sounds awesome.
Old 03-14-2014, 08:18 PM
BudRacing's Avatar
Those are badass little cars to start with, but this is just beyond comprehension. AWESOME BUILD!
Old 03-14-2014, 08:24 PM
superdave84's Avatar
very cool
Old 03-15-2014, 05:52 PM
Thanks guys! We'll be on the dyno in a week or 2 to see how it does!
Old 03-18-2014, 09:16 PM
highlanderd's Avatar
Looking good guys! The car is using our Weapons Grade Performance swap kit engine and trans mounts!
Old 03-18-2014, 11:03 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
What's the rear end in those cars? I imagine that it can't be super strong...
Andrew
Old 03-19-2014, 12:33 AM
slowbu's Avatar
Freaking awesome!!
Should be a killer drift car now lol
I do feel sorry for the I.r.s
Toyota/Subaru, probably didn't take in count of somebody smarter then them to put a V8 in there car lol
Old 03-19-2014, 08:59 AM
Envy's Avatar
This thing is dirty, sounds like a killer too.
Old 03-19-2014, 10:59 AM
Also, please remove that junky *** Russell fitting off the fuel rail unless you want that gorgeous car to be burned down to the ground. Take that rail and have a -6 fitting welded to it.
Andrew
Old 03-20-2014, 05:28 PM
rpturbo's Avatar
Wow, just wow!!! I guess you guys did all of the wiring in it to run 2 ecu's?
Old 03-20-2014, 08:23 PM
Andrew
Stock gears are around 4.10 ratio i think. It held the power when it was turbo at 477rwhp and 360tq. But when it does blow, there's a mount kit to use the Ford 8.8 rear that will be going in next.
Andrew
I've been reading up on those... I am 100% sure that it is "Properly clicked in place" because I read that the problem is when they are not properly installed they will blow off. Should I still be concerned?
The factory ECU and body side harness remain the same. The GM ECU controls the powertrain and shares a handful of wires with the factory body harness.
Old 03-21-2014, 06:30 PM
Jimbo1367's Avatar
This is the new improved/replacment fitting.
http://static.summitracing.com/globa...-644113_xl.jpg
http://www.summitracing.com/search/b...=efi%20adapter
Old 03-24-2014, 07:54 PM
Thanks so much!
Old 04-14-2014, 01:29 PM
OutlawDrifter's Avatar
this is definitely one tuner i would drive.
Old 04-14-2014, 05:56 PM
Verz's Avatar
Always love foreign cars with ls swaps, with how tail happy those things are I bet its a blast to drive
Quick Reply: Pure Automotive's FR-SS, Modified LS2 / T56 Swap, 2013 Scion FRS - Video Inside!
