Anyone Running Carshops 1 1/2" Setback Mounts In A 1969 Camaro?
Old 05-28-2014, 08:21 PM
Hondaminitrail's Avatar
Thumbs up Anyone Running Carshops 1 1/2" Setback Mounts In A 1969 Camaro?
I'm getting ready to start putting a LS1 in my 69 camaro and wondering if I need to change to a big block heater box or will the small block work. Just wondering if the engine will clear the heater core nipples sticking out of the firewall.
Thanks for any help.
Old 05-28-2014, 08:28 PM
I mean 1" setback plates.
Old 05-28-2014, 10:09 PM
bczee's Avatar
1" setback would put the engine pretty close to the fire way.. might need a little help with a BFH on the trans tunnel, depending on what your using or how it ends up being mounted. With the 1" Setback. I don't think you will have room for the SBC/6cyl as the heats will be right up there on the nipples.
Suggest you swap the heater core out for a BBC one, just buy the retainer and drill the cover. Plug up the old heater core holes.. and you should be fine, It is what I did on my Nova..
Old 05-28-2014, 10:21 PM
Restricted User
JoeNova's Avatar
I'd recommend going to the big block heater core. 1" setback mounts cause your valve covers to pretty much hug the heater core ends, and if your coils are still on the covers, its only going to further complicate things.
Old 05-29-2014, 08:00 AM
Thanks guys. I'm going with a t-56 Magnum. I'm also replacing all the subframe bushings as well. Do you think I'll have to modify the trans tunnel. The kit came from American Powertrain.
Old 05-29-2014, 08:42 AM
88Fbody6L's Avatar
I have a Nova that I tried 1" setbacks. It hit the heater housing. I ended up swapping to the big block core and housing and running Dingo sliders. My engine is about 5/8" forward of the SBC location going by the transmission mount.
Old 05-29-2014, 10:10 AM
Toddoky's Avatar
The new Hooker 1st-gen F-body/3rd-gen X-body engine mount brackets and crossmembers permit installation of an LS engine into your car using the stock SB heater core without interference issues with the core nipples. You can also use the stock A/C evaporator housing if you so choose. [IMG][/IMG]
Quick Reply: Anyone Running Carshops 1 1/2" Setback Mounts In A 1969 Camaro?
