90 mustang lsx swap stock gauge question?
has anyone resued there stock gauges on a lsx swaped mustang? I have a customer that wants to reuse his gauge to keep cost down. I have searched and seen must ppl running aftermarket gauges or the f-body gauges. Customer has aftermarket gauges for oil, water and voltage. but wants to reuse the stock gauge for the speed and fuel and rpm.
We used stock gauges in our fox body swap used the rpm, volts, and fuel the only guage that doesn't work is speedo because of trans we used didn't use the same pick up I'm sure there's a easy conversion for speedo we just haven't got around to doing so but all others will work. We did the same for oil pressure and temp as u with aftermarket guages
