LS Conversion under hood pics how/where you ran the harness
I'm mocking up my harness on the LS conversion for my 66 C10 and I'd like to see some shots of how you guys ran your harness just to ensure there isn't a better way to do it. Also after mock up, did you guys just drill a hole in the firewall and feed it through from inside out? What size hole was needed? Where did you run through? Thanks
Chris Cool project. I just subscribed to your build thread. I have a 66 Chevy long box I'm getting ready to swap a 5.3 in. Are you a member on 67-72 chevy truck website?
crusin'73 real clean install. Your engine bay looks great.
Kinda hard to see from this pic but I went for the clean look on this install. I will try and find a better pic. The Mustang has a large hole in the pass side fender area to run all the wiring through, my ECU is in the glove box.
I'm kinda' with oldgoat on this one...
I went the route that I wanted all of my wiring out in the open, where if I had an issue, I didn't have to hunt for an answer...
But...I also wanted mine to look as much like a "sleeper" as I could...
Yep I'm a member over there as well under this same screen name. Have a build thread here and there.
Homemade87,
That looks clean. Any build threads/pics?
I do not have a build thread. It was a total resto. It was painted apart and then assembled. It really did make a difference on the out come.It is just as nice from bumper to bumper. I do have pictures but I don't want to clutter this threat. Here's just a couple.
I did find another picture of the grommet I used to go thru the firewall. I took it off and old harness and split it to make it work on the harness. Worked out good.
Chris,
The harness will usually fit through a 1-5/8" hole (minimum) in the firewall. That said a 2" diameter (panel hole) grommet might be easier to find. A quick search on fleabay for 2" Rubber Grommet will get you what you need if you can't find one that big at the local hardware store.
Feed engine and trans ends from inside to out starting with the biggest connectors first. The last ones to poke through should be the ECT, VSS and ISS. It will seem like they all won't go but they should.
Being that your harness began life as a truck harness it will be predisposed to a location on the left side of the truck and your Alternator plug might come up a bit short if you go in cab with the PCM. It's not a big deal to add a few inches to the two wires though. Let me know if you need a care package sent with the wires for custom lengthening.
Considering the original length of the harness, if you want the PCM in the cab, it will need to be on located near the center of the dash or toward the driver side. You can do a test of PCM location by getting a piece of rope 42" long. Tape it to the driver side coil pack main connector and that is your "leash length" for the PCM and your harness.
I'm not on here all of the time so if you have other questions just give me a call.
Regards,
Regards,
Ken
I build wiring and despise seeing it in an engine bay. If there is a problem, it can be removed entirely in about the same time it takes to change the plugs/wires for easy diagnostics and repairs
2" hole the harness passes through the firewall. I use 3/8 hose split long ways, but common grommets also work
I am not a fan of visible wiring, so I use heat shrink on the connector ends and top side harness to keep it as thin as possible, then use other parts to block as much visibility of the harness as possible.
At the firewall, I use the stock Fiero part to protect and retain the harness as it passes through a square hole in the firewall (plastic retaining clip on other side):
