77 Pontiac CanAm Build
Hey all...Been lurking here for quite a while. This fall I started on my 2nd swap: A 1977 Pontiac CanAm. Yes, the "other a-body".
Here the info:
It's a 6.0L LQ4 with a 4l80e behind it.
Modified trailblazer SS manifolds
Dirty Dingo mounts with the x-member cut a bit
GM muscle car pan (its a little too low, but I already bought it)
Tanks INC conversion setup for the tank
Wiring harness is the stock truck harness that I modified and added a Sunfire fuse block for.
Its currently very close to running...here's some pics for amusement sake (more to come, but this is all I have on my phone currently):
Original 400/TH400
LQ4 before cleanup
Test fit with shaker dropped on top
Cut to crossmember
Plated crossmember
Shaved truck intake
Passenger side exhaust
Progress
Firewall cleanup and final mock up
Harness assembly
Diesel pedal VS stocker
Tanks INC installed
Trunk floor to fuel system clearance
Here the info:
Original 400/TH400
LQ4 before cleanup
Cut to crossmember
Plated crossmember
Shaved truck intake
Progress
Harness assembly
Tanks INC installed
The following users liked this post:
Raybob9289 (10-13-2023)
Loven it , dont see too many of those anymore , 6 oh should move all that weight quite well .. What trany are you useing , the TH400 ? ,, I would love to see that car up in the back alittle with some fat M an H tires , posi , 6 oh will definaty smoke um alot better than the old smog 4oo did , you are more than doubling the power ,, their rateing was 183 and 200 ,, nice job on the front crossmember also
Quite a bit more progress since the last post. Been driving it pretty regularly. Probably 500 miles or more so far. Got the mock shaker scoop installed (painted one hasnt been drilled yet). Speedometer is figured out thanks to a junkyard van cluster and I swapped in some 05 Mustang seats because the stockers are horribly uncomfortable. Enjoy the pics!
awesome car o love these lemans / can ams I have a 73 lemans and a 75 both are currently under the knife getting a 5.3 in one and a 6.0 in the other and why did you have to cut the crossmember ?
Cross member was notched so I didnt have to run spacers under the motor mounts. I used the stupid muscle car pan and it was on the cross member with stock SBC mounts. Lowering the motor down also cleaned up the overall drivetrain angle as well. If I had used the fancy holley oil pan, MAYBE would not have notched it.
