Rowdy burnouts and loud noises: The LSX/Subaru swap project
Old 11-07-2015, 03:50 PM
  #81
Teddy-2000RS's Avatar
Decent progress today. Finally got my engine angle to zero and I've got about an inch of pan clearance when I pick up my canton pan.
It will also clear a car intake no problem so with a stock L hood.
Of course the the engine angle came at a cost. I cut the tunnel all the way back to the shifter hole but the motor is exactly where I want it and will give me miles of room between the asphalt and my oil pan so I can still go as low as I want suspension wise.
And finished up the day cutting out the pieces for the engine side of the mounts.
Old 11-08-2015, 06:36 PM
  #82
Top engine mounts tacked and shaped.. I'll gusset them after I finish the bottom portion of the mounts.
Old 11-09-2015, 03:22 PM
  #83
First part of the bottom mount done
Old 11-11-2015, 03:35 PM
  #84
It between studying for finals I tacked up the second upright.
Old 11-11-2015, 07:12 PM
  #85
AussieDan's Avatar
Looking good, now time to triangulate everything so it can handle All The Torques!
Old 11-11-2015, 08:26 PM
  #86
Project GatTagO's Avatar
Received 1,388 Likes on 877 Posts
Might want to stick a pan on there just to make sure it fits.
Andrew
The following users liked this post:
Jimbo1367 (08-14-2021)
Old 11-11-2015, 08:30 PM
  #87
I'm planning to use cantons front sump swap pan so I went on to the 240 forums, got the dimensions, and replicated it out of cardboard so I didn't have to get one quite yet.
Old 11-11-2015, 09:01 PM
  #88
Is that a joint in the front crossover tube? Needed a tubing stretcher?
Andrew
Old 11-11-2015, 09:06 PM
  #89
When I was bending the two main tubes I forget to add in the fact that the frame rails aren't parallel and widen towards the front. This left my front tube 3/4" too short. Thankfully this is my jig and I just cut it in half and welded a piece in the center. When I remake it I'll compensate for the added rail width.
Old 11-12-2015, 01:41 PM
  #90
Got the uprights welded in and test fit it on the factory subframe. Everything lines up so its time for bracing.
Old 11-12-2015, 10:31 PM
  #91
truckdoug's Avatar
dude, i like your style.
what tubing is that and what are you bending it with? I tried the harbor freight tube kinker but all it did was **** me off.
Old 11-13-2015, 04:52 AM
  #92
Im using all 1" .120 wall Dom.. This is scrap from my roommates bobber frame. I'm ordering more for the final assembly of my subframes. What you see now are just jigs to confirm everything fits right.
Old 11-14-2015, 06:14 PM
  #93
Motor mounts braced
Old 11-14-2015, 07:54 PM
  #94
truckdoug's Avatar
Looks solid. What are you bending that tube with?
Old 11-14-2015, 10:24 PM
  #95
Harbor freight bender with padded dies and capped ends.
Old 11-15-2015, 08:44 AM
  #96
gtfoxy's Avatar
I love it when people do awesome stuff without fancy shops & expensive equipment. This should be quite the lesson in automotive enginuity for your career & life.
I'm looking forward to seeing it finished.
Old 11-15-2015, 05:09 PM
  #97
Thanks! Its certainly a steep learning curve but its well worth it.
And bolted to the engine
Old 11-16-2015, 09:54 AM
  #98
gtfoxy's Avatar
Nice.
Only thing I would have done was use a tad thicker plates for the mounts. I believe I did mine out of 1/4". It's one area you don't want any flex. I also added a vertical, angle cut, on each side.
Old 11-19-2015, 04:51 PM
  #99
^^Hmm I'll keep that in mind. I based them off other kits I've seen so I'll do some looking around before they're finalized.
And my 06 sti control arms and solid end links showed up today. Extra 5mm per side, lighter than stock, and allow me to use 5x114 knuckles. (For you non-subaru guys on here)
Old 11-29-2015, 02:30 PM
  #100
SWRocket's Avatar
Originally Posted by Teddy-2000RS
Motor mounts are next
GREAT PROJECT!
Have you tried the engine with the heads and intake manifold?
Quick Reply: Rowdy burnouts and loud noises: The LSX/Subaru swap project
