new edge Mustang swap with factory gauges
Old 05-24-2015, 04:13 PM
zipster's Avatar
Default new edge Mustang swap with factory gauges
Anyone have working factory 99-2004 Mustang gauges? I think I have a solution, but I want to see if anyone has actually done it. I know I can use f body gauges, but I want the OEM look. Let me know, I have a 2000GT, with a rod knocking 4.6, engine and trans are out. Have a 4.8/4l60e going in. Just going to be a cam/headers swap. Trying to keep it as stock appearing s possible.
Old 06-01-2015, 08:24 PM
abcgeiger's Avatar
Im in the process of a 5.3 swap in my 2000 Gt so I will be subscribing to this thread.
Old 06-04-2015, 07:17 PM
lilpanther's Avatar
This is from one of the LS Mustang groups.
To keep the factory gauges you need to keep the 4.6 PCM in the car. You are going to install the sensors from the 4.6 in the corresponding location on the LS engine. If staying fuel injected LS you have to use the passenger head and tap for the ford sender for water temp. Oil can be either rear of the block, or behind power steering pump. There is a hex head plug to remove. strip out what you dont need from the mustang harness and keep the sender wiring. gauges will work. For speedo, you will need a Dakota Digital SIG-5 convertor box. You are going to use the 2 VSS wires from the tail shaft on the trans to the box output, then from the PCM (red pin 50) to the input on the DD box (just read the instructions..) This will get the speedo working. On the ford PCM cut the white/pink wire at Pin 48 (or whatever color it is) and connect that to red pin 10 on the LS PCM. Volt and fuel will work regardless. This will retain all factory gauges, odometer. If you are really crafty, you can also get the cruise control to work... PCM is getting all the signals it needs to enable it....
Old 06-04-2015, 09:51 PM
zipster's Avatar
I did see this, when I checked the schematic, it refers wire pin 48 at the EEC5. however, this is for the 1994-1998 only. The 1999-2004 is completely different. It used CANBUS to control the cruise, ABS, and speedo and tach in the cluster. I have most of it figured out, unfortunately, it will have to be with the older 1994-1998 cluster. Now there slight wiring pinout differences with the 1994-1997 to the 1998.
The plugs are different on the 1994-1998 to the 1999-2004. But most of the colors are the same. The airbag module does not need anything from the EEC5. Cruise needs a speed signal 8k ppm. ABS I am removing. The tach will get a signal from the GM ECM that was converted to 8 cyl in the GM programming. The speedo signal from the GM ECM will go through a Dakota Digital SIG-5, converting it to 8k ppm and go to the cruise and speedo.
I am using a cluster from a 1997 Cobra. I will use the Ford temp and oil pressure senders.
I removed everything from under the passenger side fender, CCRM, harness, EEC5, some emission valve thing.
The GM ECM fits where the EEC5 was. I will add photos later.....
Old 03-21-2022, 09:18 PM
cj753357's Avatar
did you ever get it working with99-04 gauges?
Old 03-22-2022, 04:15 AM
69-chvl's Avatar
Swap in an older Mustang Dash (94-98) and your good. Just have to do some splicing.
Old 03-22-2022, 07:48 AM
cj753357's Avatar
do I have to disable pats for it to work or am I good just swapping them?
Old 03-22-2022, 10:16 AM
69-chvl's Avatar
not sure what your master plan is but I’m not using the ford ecm for anything really. I’m using a Holley to run the engine. No vats issues for me at all, and I didn’t do anything regarding vats. Even my air bag and anti lock indicators work. only thing I couldn’t get working is the seat belt and traction control lights.
https://ls1tech.com/forums/conversio...l-options.html
Old 03-22-2022, 10:46 AM
cj753357's Avatar
im running stock ls wiring harness that I’ve reworked and was wondering if I could leave the ford computer to keep keys working with doors and what not while having a functional dash
Old 03-22-2022, 11:54 AM
ryeguy2006a's Avatar
I was reading on one of the Holley forums, that you can use one or more of the outputs from Holley to mimic the cam/crank sensor outputs so that you can route those signals to the factory ECU.
The following users liked this post:
lstransam (09-01-2023)
Quick Reply: new edge Mustang swap with factory gauges
