What throttle cable are guys using for A-Bodies with stock 5.3
Was really one of the easier parts of the swap...like I said, that's the cable from the 2002 Suburban 5.3 donor rig...
I think I had to bend the top rod on my throttle pedal to get WOT after I took this photo...
Thanks again for the input. I went to the junkyard and got a cable from a Tahoe for 8 bucks and it appears to work fine. I had to make a small cut for the cable to fit and slightly enlarge the hole on my firewall and that's it.
Good catch Andrew...as you can see, I was still in the "mock up" stage at this point...
It was on there for my fuel pressure testing for my in tank pump install on my A-body wagon...
I was in a hurry and used it till I got my AN fitting from Swageloc...(like the one on the return below it)
