What aftermarket radiator are you using?
I have to order a radiator for my 55, I am going with an over sized cross flow that will need to have some good puller fans. I have a good size intercooler in front of it so I want something that will do the job. Turbo 6.0 Thanks
My existing radiator is about do for replacement. I'm going to try one of these next.
http://www.eastwood.com/triflow
Not many size options though.
I have seen these also and they look like a great idea, It has mixed results when you start to ask about it on the internet. I hate to feel like the guinea pig and it not work out. I am having it custom mounted due to not being able to use the stock core support, so it would be a real pain to have to replace it if it doesn't perform well.
I am using a Howe Racing radiator, these are made in USA in standard sizes or to your specs. Mine is in the front trunk of a Porsche 914 cooling my ls6 (mid-engine), and is very effective.
Don't make the mistake I did and cheap out on the fans. If you are running Ac u will need 4000 cfm. I love my champion rad but the fans that came with it are not strong enough . So I found some slightly used derale H.O fans on ebay. If I had to do it over again , I would've bought my rad without fans and bought the derale set up new.
