LS1 w/4l80 Cruise Control
I have a 2001 Trans Am that I just got back from a 4l80 conversion. The cruise control and hatch button worked prior to this conversion, now they no longer work. Does anyone know how to fix this? I haven't been able to find a solution on the Google.
4L60E to 80E there is no difference in cruise wiring unless you forgot to plug something in
M6 to 4L80E you prob forgot the brake switch wire because M6 do not use it
Hatch release is more likely from M6 to 80E. M6 cars must have the Ebrake pulled to release where auto cars require being put in park. Compare the hatch release circuit for both and amend as needed
