Adding pins to red / blue PCM?
Old 07-15-2015, 06:52 PM
StolenFox's Avatar
Default Adding pins to red / blue PCM?
How do you remove to plugs that block of certain pins in the red and blue connectors for the 411 PCM? I need to add a few wires for e-fans and manual trans on the harness I'm converting to stand alone.
Thanks!
S.F.
Old 07-15-2015, 09:58 PM
ls1nova71's Avatar
You just push the pin through the rubber. A straight pin to poke the hole may make it a little easier.
Old 07-16-2015, 06:27 AM
StolenFox's Avatar
Great, I was hoping that would work. Thanks for confirming!
S.F.
Old 07-16-2015, 10:25 AM
groundczero's Avatar
What nova said, this video shows easiest way to remove if you put it in the wrong whole.
Quick Reply: Adding pins to red / blue PCM?
