My Turbo LSX Z31 Build.
Old 06-02-2016, 05:15 PM
  #81
Nismo Kid's Avatar
Disassembly began
Old 06-02-2016, 05:18 PM
  #82
Nismo Kid's Avatar
Removal of the high pressure seal & inner tube seal
Old 06-02-2016, 05:20 PM
  #83
Nismo Kid's Avatar
Cleaned everything up
Old 06-02-2016, 05:21 PM
  #84
Nismo Kid's Avatar
Old 06-02-2016, 05:24 PM
  #85
Nismo Kid's Avatar
Old 06-02-2016, 05:25 PM
  #86
Nismo Kid's Avatar
Let the assembly begin!
Old 06-02-2016, 05:26 PM
  #87
Nismo Kid's Avatar
Old 06-02-2016, 05:28 PM
  #88
Nismo Kid's Avatar
Old 06-02-2016, 05:29 PM
  #89
Nismo Kid's Avatar
After it was all assembled I gave it a fresh coat of paint for protection.
Old 06-02-2016, 05:34 PM
  #90
Nismo Kid's Avatar
I ordered some grease fittings for the finishing touch. But I'm still waiting on them to arrive. That way I could grease my steering rack during routine maintenance. I'll add some pics in my next update.
Sold vs Factory rubber bushing
Installed manual rack with new sold bushing.
Old 06-02-2016, 05:36 PM
  #91
Nismo Kid's Avatar
Here's my new clutch & flywheel in all their glory.
Old 06-02-2016, 05:38 PM
  #92
Nismo Kid's Avatar
The standard length LSX flywheel bolts were just a tad to short. So I ordered some extended length ARP bolts #244-2902.
Now I installed the flywheel & clutch onto the 4.8.
Decided to clean the transmission up a bit.
Old 06-02-2016, 05:39 PM
  #93
Nismo Kid's Avatar
Installed the clutch fork dust boot, chromoly pivot ball, 350z clutch fork, throw out bearing & sleeve
Old 06-02-2016, 05:40 PM
  #94
Nismo Kid's Avatar
Then I mounted my transmission to my engine.
I finally installed my engine & transmission back into my Z!
Old 06-02-2016, 05:41 PM
  #95
Nismo Kid's Avatar
It's beginning to resemble a car again. Lol
I told myself I wouldn't install the kit until I got it Ceramic coated but I couldn't take it anymore.
Old 06-02-2016, 05:42 PM
  #96
Nismo Kid's Avatar
Old 06-02-2016, 05:44 PM
  #97
Nismo Kid's Avatar
With the engine & transmission in I began to install more parts from my collection.
Installed the rebuilt starter
Purchased a new brake booster, z32 brake master cylinder, z32 clutch master & slave cylinders.
Decided to paint my booster prior to install.
Installed the brake booster, brake master cylinder & all the clutch hydraulics.
Old 06-02-2016, 05:45 PM
  #98
Nismo Kid's Avatar
To finish up the 4.8 I installed my injectors, fuel rails, intake manifold, billet EGR block off, alternator, billet belt tensioner, & serpentine belt.
Old 06-02-2016, 05:46 PM
  #99
Nismo Kid's Avatar
I also reworked/wire tucked my gold box harness. I relocated the coil pack plugs & coolant temperature sensor plug without any cutting of the harness.
My main goal is reaching 180+mph in a standing mile. I'd also like to trap 135mph+ in the 1/4. I wouldn't mind seeing if this little 4.8 can make 600whp on E85. It'll still be stock bottom end & stock cylinder heads. I'm not really too concerned with a dyno sheet. I'd be ecstatic if I could reach any of my goals with this little 4.8. I should have another small update within the next couple months. Thanks for stopping by.
Old 06-02-2016, 05:55 PM
  #100
Nismo Kid's Avatar
Originally Posted by slocaddy
The fit/finish/layout is freaking outstanding! Nice build
Thanks man.
Quick Reply: My Turbo LSX Z31 Build.
