Oh hello LS 370z
#43
The brunette on the drivers side, I believe she's newer is awfull. Bring the other blonde back, IIRC.... Jesse Comb
#45
Just went through an re-read this post. Very cool build, and good info about the AN-fittings. Clean build, I bet she's a blast.
PS. I would like to shout out a warm and friendly **** YOU to the "all dykes garage" comment, because ignorance is not awesome.
#46
#47
so i changed out the fuel fittings. here are the ones by the filter/regulator..
before
after
forgot before and after pic for the fuel rail but the fitting doesnt seem tight..i can wiggle it some
http://vid393.photobucket.com/albums...ps8gfn9sd1.mp4
before
after
#49
I got to drive around for a few days. didn't want to go too far since i dont have exhaust. only longtube headers
Ls370z out and about #Ls370z - YouTube
Nice clean Swap !!!
#50
So what's with the shmootz on the AN mating surfaces of your new fittings? AN fittings are designed specifically not to need or use sealing agents on those surfaces. If that stuff ever deteriorates expect a leak, or worse.
#52
Nice to see another Z swap. Seems to be a good amount of them on here(ls1tech)
Kind of wondering why you did the cross-over pipe on the exhaust on #49.
I own a 350z (swap) and was asked about a cross-over I was told it's not a mustang.
I am running AAM 3' duel and I have no cross-over.
#55
i was looking at x vs h and just went that way
