NNBS intake on a 6.0 Jeep YJ swap.
I've read the specifics, but what would be required on a swap? I have a 2004 6.0/799 heads that I'm installing in a 1995 Jeep YJ. I'm running a 4l65e with a NP241 transfer case. I know the injector connectors are different. I pretty sure I wouldn't need the gas tank blow off valve..or whatever it is. What all else is different? The only reason I'm considering a NNBS swap is all the NBS intakes I find are $150+. I might as well add some hp if I gotta spend $200 on an intake. Thanks.
