New Hooker 1968-72 A-Body LS Swap System Preview - Page 3 - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Old 11-01-2015, 04:08 PM
  #41
Originally Posted by rallystyle View Post
todd
will there be room for a low mount alt from a camaro or gto setup? any pics of the room from the engine to the firewall?
Yes, the 4th-gen F-body alternator will bolt right in if you use the rear-position engine mounting brackets, but not with the forward-mount engine brackets. I have a GTO alternator and will be test fitting it for compatibility before I'm done with the development work on this project.
Toddoky is offline
Old 11-01-2015, 04:41 PM
  #42
Alwhite00's Avatar
Looking forward to more updates.
Alwhite00 is offline
Old 11-02-2015, 12:44 PM
  #43
Default Truck compressor fitment validation
I've mocked-up the installation of the stock truck A/C bracket and compressor with the forward position mounts and am posting these photos for those interested. I can also tell from measurements that you'll also be able to install this same late version truck compressor (the one without the rear sensor), when using the stock-position version of the engine mounting brackets, by just relieving the compressor bracket a little with a rotary file chucked in a die grinder. Here you go...
Toddoky is offline
Old 11-02-2015, 01:12 PM
  #44
Alwhite00's Avatar
Nice.
Old 11-02-2015, 03:15 PM
  #45
I forgot the all-important ground clearance shots...the transmission in the car currently is a 4L60 and you can see in the side image that the outlets of the collectors are just about even with the bottom of the trans pan.
Toddoky is offline
Old 11-02-2015, 04:12 PM
  #46
Todd your stuff look great! Can't say the same for that lower cowl and nasty frame on my car-LOL. I do look forward to fixing that body rust, boxing up the frame and installing SC&C's modern suspension and brakes.
968ls1 is offline
Old 11-02-2015, 04:20 PM
  #47
Thanks for your approval of the progress so far. As far as your car goes, trust me when I tell you I've worked on far worse off specimens before.
Toddoky is offline
Old 11-02-2015, 07:07 PM
  #48
the450r's Avatar
I don't mean to high jack but they recommend not using those compressors with vintage/ classic air. The fitment for the gto style isn't ideal because the lines hook up points right at the a body frame.
the450r is offline
Old 11-02-2015, 07:28 PM
  #49
It's not my place to tell people what components they should or shouldn't use in their swaps and I just answer the questions as they are asked. The ability of this set-up to accomodate stock low-mount A/C compressors is a secondary by-chance benefit of its use, with its primary engineered function being its ability to eliminate the steering component interference and non-optimized U-joint operating angles that have plagued A-body swaps for years.
Toddoky is offline
Old 11-03-2015, 09:38 AM
  #50
Project GatTagO's Avatar
Todd,
Am I to assume that there will be one version of the headers that accommodates both engine positions?
Andrew
Project GatTagO is offline
Old 11-03-2015, 10:22 AM
  #51
Gray86hatch's Avatar
I have been using the stock location non variable truck compressor on dad's a body for 5 years and 25 '000 miles with vintage air with no issues.
Gray86hatch is offline
Old 11-03-2015, 11:18 AM
  #52
Originally Posted by Project GatTagO View Post
Todd,
Andrew
That's correct Andrew, the same headers work with both sets of mounts.
Toddoky is offline
Old 11-03-2015, 11:20 AM
  #53
Thanks for confirming that. I did some of my own research last night and discovered that many guys have used the fixed displacement stock truck compressors with success in their swaps.
Toddoky is offline
Old 11-03-2015, 06:37 PM
  #54
How do I place an order for the frame and engine mounts, and the headers?
69 Custom S Vert is offline
Old 11-03-2015, 07:32 PM
  #55
Alwhite00's Avatar
Had to post, I hit the damn unsubscribe tab on my phone.��
Old 11-03-2015, 07:35 PM
  #56
Placing an order for any of these components is not yet possible, but will be in the near future. The 1-7/8" version of the headers will be available within a couple of weeks and the engine brackets will follow just behind them. The Hooker trans crossmember In development will only be required for a T56 or 4L80 install; all the other automatics can be installed with the stock Chevelle crossmember.
Toddoky is offline
Old 11-04-2015, 09:02 AM
  #57
I have a 408 stroker. Would have loved to use the Holley 302-2 pan, but had to go with an autokraft to accomodate the stroker crank. I know I'll have some tie-rod interference at full lock. I can live with that. Otherwise, do you think the geometry of your frame and motor mounts and headers will play well with the autokraft pan.
Old 11-04-2015, 09:17 AM
  #58
Default trans tunnel
Will your kit require any modifying of the trans tunnel with the 80 or 85 trans?
oldstv is offline
Old 11-04-2015, 10:52 AM
  #59
Those headers look amazing. Love the 1 7/8" primaries. Any plans for a version for 64-67 A-bodies? The market is very lacking in long-tube headers for the 64-67 cars, especially with 1 7/8" primaries.
Thanks,
Jeff
67 goat is offline
Old 11-04-2015, 11:54 AM
  #60
I can't speak for the compatibility of these new components with the Autocraft pan as I don't have any first-hand experience with it...the sump of the Holley 302-2 pan is 9.75" long, so that should give you some comparative information you can use to compare it to the sump length of your pan. The photos shown so far depict the position of the engine on the forward position Hooker mounting brackets; the rear position mounting brackets place everything 1.25" further back in the chassis at the stock location of the engine/trans mating plane, so they set-up may work for you. It is possible to use the 302-2 pan with a stroker crank if you are willing/capable of modifying the pan such as the user who took this photo has done...
Toddoky is offline
Quick Reply: New Hooker 1968-72 A-Body LS Swap System Preview
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
