New Hooker 1968-72 A-Body LS Swap System Preview
#101
I test fit the new Hooker A-body headers on an engine mounted on a stand with common 1" set-back LS swap plates and old school mounts...they fit with no problems, so any of you using those types of mounts in your A-body that are needed a set of headers should be able to use these headers with good results, even though you won't benefit from the geometry advantages offered by the Hooker engine brackets. Here's a look...
#103
Imo...the exhaust bung is in the wrong location. They need to be on the inside of the header to eliminate crossing wires over hot exhaust. Additionally...consider bungs on both sides of each header. One for narrow band and the other for wide band tuning. Sucks having to drill and weld after the fact.
#104
I suppose that could be a problem with that trans. However...my Speartech harness or the sensor wires would have to pass directly over the header to mate up with the ecm harness with an outward facing O2 bung. Not sure how long that would last.
Some prefer tail pipe wide band adapters. I prefer header mounted
#105
#107
Have frequented this site for years, but have only recently registered - first post here.
Great thread and great pics and insight. Thanks for all the updates.
FTR. In the process of moving a running and driving L99/6L80 from a 14 SS Camaro donor into my 70 Malibu. Was hoping to keep the entire OEM setup intact just like from the factory, which turns out to be a loft goal.
The L99 pan has some attachments that are not common to all LS engines and the proximity of wiring harnesses under the engine, hoses and piping crossing under the pan would require a total redo, which would then lead to other changes.
Can't even get the standard A-body motor mounts to come within 6" of the A-body cross member. While changing the pan would get it close enough, that would then lead to a lot of other changes.
Planning on cutting the cross member out and welding in the cradle from the Camaro.
Here's a pic taken with me on a creeper and the car on the lift.
Nick
Nick
#108
Nick
Nick
#109
For those with interest, the first run of 1-7/8" headers are on the shelf and available to ship. The quantities are limited, so I wouldn't hesitate to long if you're trying to stay on top of a schedule you've set for yourself.
#112
todd
may want the web people to check some stuff on the site.
Allows installation of a GM TH350, TH400, TH2004R, 4L60-4L70or 4L80/4L85 transmission using a factory 1968-72 Chevelle transmission crossmember, without having to cut the vehicle floor open
4L60-4L70, 4th-gen F-body T56/T56 Magnum or 4L80/4L85 transmission installations require extensive floor cutting; T56/T56 Magnum and 4L80/4L85 installations require the use of a Hooker 71222007HKR transmission crossmember
the 4l80 is in both the cutting and not cutting . and the use of the cross member .
#116
todd
#118
Toddoky, I have a couple questions for you.
1. Your forward engine mounts, how much further forward does it move the engine?
2. When moving the engine forward, how much room is there between the oil pan sump and the crossmember? Reason I ask is i have your 302-2 pan with the engine mounted back 1" from stock SBC location, and I remember there not being much clearance with the cross member.
3. You mentioned getting the angles of the drive train correct. What angle do you set the engine and transmission to? Also then what should the rear end angle be set to?
Also how much are these stainless 1 7/8" headers selling for? they look really nice. If i leave my engine at 1" set back will it still clear and fit?
Thanks for all the help and good work on developing A body stuff.
#120
