LS3 -> 58X or 24X?
LS3 -> 58X or 24X?
I've been looking at harnesses at a couple different vendors. ONe lists LS3 under 58X and the other lists it under 24X.
I have the crate LS3 / 430 engine from Jegs.
Not sure what else I need to know in order to order all the stuff I need. I know I need a harness, ECM, Pedal, drive by wire.
Probably some type of MAF.
Do I need a TAC module for Cruise control stuff? Seems when I look at those, they are for older cars than this LS3.
As you can probably tell, I'm pretty green.
Roger,
If you are going to buy a GM LS3 430/480/525 HP versions, GMPP sells matching harness and ECU kits. Plug and play and already tuned.
All Gen IV engines are 58 tooth and the DBW does not use a TAC module. Also, all Gen IV pedals are interchangeable (stay away from GTO pedals).
Andrew
Andrew
