E-ROD Crate Motor 4WD question
Ran into a bit of an issue on my Erod swap.
2015-12-11_12-42-17 by Jimmy Casey Photography, on Flickr
The catalytic converters that are provided in the e-rod kit don't clear the front driveshaft. I kind of figured this was the case for most 4wd trucks, so I'm curious if GM sells a setup that would accommodate this? Or if anyone else has run into this issue?
This is a california truck, so it must be emissions compliant. I'd like to explore all my options before I start fabbing something up.
Thanks guys!
Thanks guys!
