LS in Nova, building my own PS tank, vented or not?
So I am building my own aluminum power steering tank for the Ls swap in my Nova. I have the Holley accessory brackets and corvette style PS pump with remote reservoir. The Holley/Corvette reservoir won't fit with my intake setup so I have to go custom. I am running the 87 camaro quick ratio steering box.
I'm assuming the OEM reservoir has a "puke type" cap on it when pressure builds up?
My question is, do I need a vent?
If so my thoughts so far were:
1. Dirt Bike style gas tank vent
or
2. Drill a small hole in the center of the cap (~1/16" or so)
Pics for reference.
Any/all feedback is appreciated.
or
Pics for reference.
After searching the net more, I have seen more cases where people who just put a small hole in the cap.
I have also see where people use a pneumatic exhaust vent like this one.
I don't want to ruin my cap with a hole in case it doesn't work, so I think I'll weld a 1/4" npt boss on the tank, and either screw in a pipe plug with a small hole in it, or screw in one of those exhaust fittings.
Yes I have a complete build thread here, first post has the table of contents.
http://www.stevesnovasite.com/forums...d.php?t=281657
threaded aluminum bung
You might consider a weld in threaded bung with vented cap. They come in a multitude of size as come weldable steel or aluminum. As I am having reservoir clearance issues with my LS1, which is going in a 36' Chevy coupe, I am cutting off the neck and welding this one in. They make for a very clean install.
From my build thread on another forum. Thanks everyone for your feedback.
So I had some time this evening to TIG up the power steering reservoir. I also machined a bulkhead/bung to mount my little vent. I made it with an integrated baffle to help keep leakage down. I still need to make mounts for it, but need to buy some aluminum flat bar.
First up I cut a chunk of aluminum rod off and machined the faces flat.
Then I drilled it 90% of the way through with a 7/16" bit. Next up was to machine a slot and pierce through to the middle. Followed by tapping it 1/4" NPT for the vent.
Next up was to drill a hole for the bung to go through. The idea is to point the slot at the cap since the walls of a tank always get more splash than the middle.
I dimpled the center of the slot so I knew how to orient it.
Welded. Its amazing how much further your Argon goes when your hose isn't leaking .
Next up build some mounts!
So I did some research today to try and wrap up the plan for the power steering system. I stumbled on an article I read before regarding steering box upgrades when looking for fitting sizes. Interestingly, it also has this nugget of info:
http://www.hotrod.com/how-to/chassis...g-box-upgrade/
Well good thing I didn't drill a hole in my cap, looks like if I have issues, I may be swapping out my vent for a 5-10psi relief valve instead.
He recommends an external reservoir for the power steering pump. Lee's reservoirs use a sealed cap that maintains 10 psi of residual pressure to improve steering pump efficiency. A large reservoir is not necessary. All the GM sheetmetal reservoirs that are integral to the pump also work very well. All plastic GM power steering reservoir caps over the last 30 years have incorporated check valves to create some residual pressure.
