no rpm signal 5.3 swap
I have a 93 camaro with a 5.3. After I did the swap I havent had rpm signal. When i connect it to any computer it will not read rpm. I runs perfectly fine. I also believe i have no rev limiter. Is there some type of sensor that may be bad and cause this problem? Any advice would be great.
Thanks
Carter
Thanks
Carter
What should I be looking for on this blue wire if i go to test this? Im not sure off the top of my head what pcm but i do know its off of a 98 ls1. Every other gauge works fine.
Thanks.
Thanks.
9 Second Club/LS1TECH Sponsor
The 93 Z28 tach still triggered off of the ignition coil negative pulse instead of a PCM type trigger, so the output from the PCM may not have enough ooomph to trigger that tach. You may need something like a dakota digital tach adapter box that has a high output tach trigger. In 94 the Camaro switched over to a PCM triggered tach.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
But besides my actual tach not working, i also dont have feedback when i connect a scan tool to my obd2. When the car is running my scan tool says 0 rpms. Is there something else that could possibly be causing both of these issues? Thanks so much for the advice so far
Carter
Carter
The instruction/installation manual for the LS3 says that the following, please review it to see if it applies to your situation. I'm wondering if a pull-up resistor might help and avoid the use of a box, but can't say.
